loading
Step 15: Solder EL Wire
This step may or may not be required. If your EL wire came soldered, awesome. If it didn't, refer to this instructable: https://www.instructables.com/id/How-to-Solder-EL-Electroluminescent-Wire/
If you have several strands connect them in parallel. Before doing this, you should have two wires coming from each strand of EL wire. Let's call them "Wire 1" and "Wire 2." Every strand has a Wire 1 and a Wire 2. Solder all of the Wire 1s together and all of the Wire 2s together. Then, attach all of the Wire 1s to one output wire on your inverter and all of the Wire 2s to the output wire.
By the way: Cool Neon (where I ordered my wire) will often include copper tape and heat shrink tubing with your order.
u know u can use paint to make a picture larger? just got to file, page set up, and where it says scaleing there should be two check boxes. one says adjust to, the other says fit to. click fit to. now just tell it how many pages it should fit to in the boxes next to it. for proof that it scaled it, go file, print preview. it will show you how many pages it fits. you may have an inch or so with nothing on it (the margins) you can adjust those in page set up too, or just cut them off when you print it out.
Some people use a wing jig for this. What you can do is tape down the outline over a piece of wood or maybe even cardboard. Then hammer in needles all around it, leaving enough space to fit the wire around the needles. This ensures every wing is symmetrical as possible. Great for those who want to make many wings for sales purposes.
To avoid this step, you can instead purchase a roll of 14 gauge galvanized steel wire form Home Depot very cheaply. Or a more expensive but better choice would be plastic coated copper wire.
Dude, sweet wings. Where did you get the striped pants? I kinda need a pair.
I made the stripped pants out of two pairs of pants. i just cut loops of fabric from the legs of one pair and sewed them on to the legs of the other pair.
i did this a few years ago
dude that is noice. you shud totally make it pulse or for epic wins, make it pulse with music. unce unce unce :D
Good idea! I'll add that to the last step.
About This Instructable
18,285views
86favorites
License:
Bio: I'm studying to be a Mechanical Engineer at Cal Poly (going into year 3).
More by DesChamos:EL Wire Fairy Wings
Add instructable to:
