EL panel lantern
EL panel lantern
I bought a cheap lot of 25 electroluminescent panels from Windsor Distributors a couple years ago, finally got around to making something out of them....
Step 1Connecting individual EL panels
I had 25 EL panels, each about 2.75" X 1.25", and made a 5-sided "night light" with 5 EL panels on each "pane" or side.
I don't have photos of the manufacture of the individual 5-panel panes. However, the basic idea is visible in the photo. Each of the 5 EL panels was attached to a piece of acrylic with a dab of hot glue, with the two leads passing through small holes to the back side. One lead from each EL panel was bent to the left and the other to the right. Then I laid 6" stripped copper wires across the left and right sets of leads, and soldered the leads to the wires. More hot glue secured the wires to keep them from wiggling around and possibly breaking the delicate leads.
25 comments
Apr 18, 2006. 11:45 AMrotor says:
"The EL panels run off of regular AC house current" I've been wondering about that - someone told me they needed 120v at 1KHz or something, so I've stayed away from these. Now that I know different, I'll be trying them soon. Great project idea, nicely executed.
Apr 28, 2011. 2:00 PMhayedid says:
Rotor, they will run of U.S. power line frequencies (60Hz); however, they will be dim. To get a bright light from EL Panels, you must run at a higher frequency. Inverters can be purchased for under 10 bucks though.
Apr 18, 2006. 12:00 PMronin.ca says:
Stupid question, are these the same things that are showing up as night lights?
Apr 28, 2011. 1:58 PMhayedid says:
I bought some EL night lights several years ago... the problem is that most of them run off 120V AC / 60 Hz... which causes the nightlight to be very dim.
Feb 12, 2010. 9:23 AMjavier22 says:
Help!!!!!!!!!! I would like to know how I can convert the 110v ac power to 12v dc to install the el panels in my car or motorcycle.
Apr 28, 2011. 1:56 PMhayedid says:
EL Panels don't run off 12V DC. They run off AC power. I disagree with guerroloco though. An inverter from WalMart would turn on your EL wire or EL panels; however, it would be running at 60Hz which would be very dim. Look up EL Wire on ebay and buy an EL wire inverter from there. Doing so, you should get the correct connectors and it will run at 1200 or more Hz which will give you a nice bright wire.
Sep 14, 2010. 8:16 PMelpanel says:
I think there is no good idea to convert it,it's better that you buy one DC12V inverter,please note that the el panel can not very big,because DC12V can drive small size el panel only.
Apr 23, 2009. 10:21 AMlonerayven says:
Hoping to find 'inexpensive' EL panels/sheets at least A4 size for my art project. >,< If anyone has any links please request, currently looking at glowtron.com as said by batibol.
Sep 14, 2010. 8:22 PMelpanel says:
what's your e-mail address?I would like to send you an e-mail.
Sep 14, 2010. 11:23 PMlonerayven says:
lonerayven@gmailDOTcom
Aug 18, 2008. 8:08 AMbatibol says:
i just bought my custom el panels from www.glowtron.com , am trying to attempt to make something really cool with it
Mar 8, 2008. 3:02 PMled235 says:
Anyone know where i can get EL Panels for under $10.00? please let me know. Great Instructable man!!!!!!!!!!!!!!!!1111
Oct 15, 2007. 6:43 PMMr. Rig It says:
Very cool. This one is gong into my favs.
May 22, 2006. 9:01 PMmyeyesdeceive says:
I just searched everywhere and came back with nothing. Has anyone seen cheap el panels around this size I have a bunch of ideas for them and would love to build smaller versions of these "lanterns" for my deck.
Jul 2, 2007. 4:50 AMstanley lee says:
Hey,friend ,we are EL panel supplier in China with many years experience . if you interested in our products, please login our website: www.konlly.com
Jun 9, 2006. 2:12 PMArcan3 says:
Dec 29, 2006. 4:48 PMQ-Branch says:
e-clec-tech has EL panels.
Aug 19, 2006. 8:42 PMbesilly says:
sounds like a great project! Hey I am new to this site but have a question I thought you might be able to answer. I have a Chrysler (GEM) Electric Car powered by 6 12 volt batteries running (I believe) in a series. I have just purchased six 5 watt solar panels (14" x 10.5 " each). I plan to mount them onthe GEM roof. Any thoughts on how to connect them up? I was thinking of directly hooking each individual panel to its' own battery. The guy I bought them from suggested installing a master disconnect switch to stop the flow of electricity when I plug the car in. Any thoughts?
Apr 20, 2006. 1:23 PMleevonk says:
what is josie? also, in case anybody wants some, I know they sell these panels at allelectronics.com
Apr 18, 2006. 6:53 PMrgbphil says:
Looks very nice, a good use of EL tiles in the style of a japanese lantern. One question, I've used cheapo EL wire but they fade brightness after a few months......have you noticed any fading on this yet?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:guerroloco
