Step 2Gluing and connecting the panes
iImage Information
I constructed a "cradle" out of scrap wood to hold two panes at the correct 108° angle, so that when all the panes were glued, they should form a perfect pentagon. I used special emblem cement; it's about the consistency of honey and would drip off if I tried to glue vertically. When dried, the corners were slightly flexible, so it needed some additional support when I glued the final pane in place. Finally I glued on a pentagonal base plate, somewhat larger than the main body. The top is held on by threaded rods, fitted through brass tubing with brass capnuts on each end.
