3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ELECTRIC FIRE
ELECTRIC FIRE
Making a basic machine to turn water into flammable gas is super easy, I'm not even 18 yet. I bet anyone with brains can make electric fire. It works by splitting water, into Hydrogen and Oxygen. Together... THEY BURN!!!!!!!
rate my instructable please, it's my first one!
Step 1Stuff you need
Stuff you need
STEP ONE: Stuff you might need.
1) Cutting tool (knife, scissors, can opener...)
2) glue or solder (hot glue, silicone, electric solder)
3) multimeter
4) small container that won't melt
5) AC to DC converter a.k.a charger that plugs into the wall or a powerful battery
6) two pieces of metal
7) piece of plastic
8) baking soda
9) you!
41 comments
1-40 of 41next »
Feb 25, 2010. 8:08 PMdirectcurrent13 says:
Important note here the water is not actually burning. electrolysis is being used to cause a decomposition of water. Creating oxygen and hydrogen "2H2O (L) yields 2H2 + O2." putting a flame to the hydrogen and oxygen causes an exothermic reaction creating water not destroying it. p.s. any ionic compound (I.E. metal bonded to non metal) may be used instead of baking soda.
 Good Instructable on electrolysis though
Jan 14, 2010. 12:30 PMknektek says:
do you have to use baking soda? can you use baking powder?
Jan 16, 2010. 3:29 AMknektek says:
thank you.
Jan 11, 2010. 12:38 PMknektek says:
couldnt you just use a 9v cell?
Jan 6, 2010. 6:45 AMtrike road poet says:
You laid out a nice simple experiment from my physios classes of 1960.  Well done and clearly a good demo of the principal.
Now for fun, get an old arc welder, use carbon rods, set up a submerged arc in water, capture the gas released (known as Brown's Gas) which you can pump into tanks and burn like propane in an engine.  The technique is likely as old as you and it is fun to play with.  The carbon from the rod joins with the hydrogen in the water to make carbon-hydrogen gas that is very burnable indeed.  I played with this in the '80's and we ran a small emergency generator on the gas rigged with a propane carburetor.
Oct 3, 2009. 6:50 PMyour dog says:
how do you power an engine with this?
Oct 8, 2009. 8:31 PMcodz30 says:
To convert the chemical potential energy of hydrogen mechanical energy two methods can be used: combustion or electrochemical conversion.
* In hydrogen internal combustion engine vehicles, the hydrogen is combusted in engines in a similar method to conventional engines
* In fuel-cell conversion, the hydrogen is reacted with oxygen to produce water and electricity, the electricity used to power motors and the like
Hope that answers your question
Sep 28, 2009. 4:17 AMjames.mcglashan says:
fire fire fire fire i love fire
do you wan to join my fire and survival group if yes click here
cheers fire lovers
Oct 3, 2009. 6:48 PMyour dog says:
yeah! pyro power!
Aug 18, 2009. 3:13 PMScienceWiz says:
Cant you use regular water in stead of having to make a solution? Correct me if I'm wrong, but doesn't the baking soda release chlorine gas? Not that it would bother me, I've dealt with many dangerous elements, but just wondering. Great instructable, makes you wonder if you could power a motor with water?!?! Real fun idea!
Aug 4, 2009. 2:36 PMfordman15243 says:
you know it's almost impossible to store hydrogen as a gas without specially contructed tanks, it would just seep throught the material that is supposed to be containing it because of it's small atomic size.
Aug 5, 2009. 6:02 PMfordman15243 says:
You know a balloon is even less airtight than a plastic bag right?
Aug 8, 2009. 3:28 PMfordman15243 says:
No, but i am a genius =]
Aug 8, 2009. 6:51 PMsharlston says:
nice ible it wilnice ible looks really cool
Jun 4, 2009. 8:17 PM123456789pos says:
good instructable how do i rate it?
May 31, 2009. 9:48 AMDuke15 says:
good thinking!
Apr 22, 2009. 3:09 PMshawntherobot says:
were do you rate it?????????? Ill be back tommorow!!!!!!!
Apr 22, 2009. 5:32 PMshawntherobot says:
you should post a picture of an explosion of the hydrogen from a side view. A picture because i cant watch the videos my computer wont load them its to old.
Mar 23, 2009. 12:18 PMshawntherobot says:
How many volts do you need to to the gas out of the water
Apr 20, 2009. 8:21 AMshawntherobot says:
it seems my parents wont let me use fire so ill do it over vacation when they go to work!!!!!!!
Apr 22, 2009. 3:04 PMshawntherobot says:
ya of coarse ill tell them that or will i hehahahahaha. I could just do it in he woods with a car battery as you said, instead of a power supply.
Apr 17, 2009. 1:56 PMshawntherobot says:
thanks i'll try it with my plugin power supply it goes up to 20 volts before the fuse burns out
Apr 14, 2009. 2:17 AMFeedTheGrid says:
Cool ible. Maybe I could power one of these with The Green Twist Machine! : - )
Apr 6, 2009. 9:31 AMstephenniall says:
This is basically Seperating Hydrogen (H) from Water (H20) Using Electrolys If you Made a container from the hydrogen with a Lead you could pump the gas into a engine (Lawnmowers are the best Not your brand spanking new car) The fuel input line to power the engine by water
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:ANDY!
i like ice-cream.
