IN THIS AREA these "water cubes" seem to be in short supply. There's a place close by that used to have them for $100 but they are out and don't know when they will have more. I'm looking for more of these if anyone knows where some are.
AUTHOR ADDED: SORRY, I MEANT TO POINT OUT THAT THIS WATER WILL OBVIOUSLY HAVE IMPURITIES IN IT. THERE ARE A LOT OF GOOD COMMENTS ABOUT WHAT MIGHT GET FLUSHED INTO THE TANK ALONG WITH THE WATER FROM THE ROOF, NOT TO MENTION THE TANK ITSELF. THIS WATER WOULD NOT BE FIT FOR HUMAN CONSUMPTION UNLESS IT IS SERIOUSLY PURIFIED FIRST. SEE MY PAGE WITH THE WATER PURIFICATION IDEA, I HAVE ADDED PICS AND INFO TO HELP EVERYONE FIND THE STUFF I USED.
![Drink Your Own Pee - [survival guide]](http://www.instructables.com/files/deriv/F5H/0MIV/F8DOZPTD/F5H0MIVF8DOZPTD.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
I do not know if the type of tanks you are using are available opaque (no light gets in), but water that is kept absolutely dark will remain fresh. City water in large above ground tanks does not have any chemicals added to it until it is sent through the distribution pipes. The pipes have cracks which make chlorine necessary. For example, there are many Texas commercial rain water equipment companies that sell to residents and advertize that their rain storage tanks do not have to treat the water so long as it is kept in opaque containers. Thanks for the informative project.
The reason cities do not treat the water until it is sent down the pipes would be due to chlorine evaporation and plant operating costs.
It all depends on geographic area, well location and depth...so just because you pulled it out of the ground does not mean it is going to be safe. Mountain streams look pure and clean too.
Some ground water may also contain chemical pollutants....this is a big one to watch for due to our modern world. With the recent ground fracturing for energy sources alot of rural areas are starting to see polluted wells.
Ceramic filters will not remove salt from the water...for that, you would need a RO or reverse osmosis filter.
To prevent freezing ...would all depend on where you live and how cold it gets there.
A low cost no power option would be to build a protective box maybe out of pallets and insulate with waste polystyrene or stack hay bales around it.
For what?
Watering your lawn?
I use similar system to do just that and never ever for drinking.
I do have "emergency" water storage and I use 55 gallon food grade plastic barrels.
I just fill up the six I have from the tap and rotate them every three months.
That gives me over 300 plus gallons of fresh water. Worried about bacteria? Just add some iodine.
Cost? $40.00..
Easy to move; flip them on their side and roll them...
If the power grid and city water is down for an extended time due to a disaster or event....rain water collection provides when your only other option would be government assists....and good luck with that one.
http://www.instructables.com/id/WATER-PURIFICATION-SYSTEM-cheap-and-effective/
Keep it up!
Theirs is set up as two tanks catch off of the equipment shed, two off of the workshop, and four more off of the house. These are pumped through one sediment filter per pair into 14 more tanks in the work shop for storage.
The water is then run through another sediment filter, a standard whole house filter, and then a UV light.
Personally I would run it through a ceramic/carbon filter after that as well but, they both seem fine even after decades of getting their water this way.
If you made your self a still then you could go down to the local storm water drain and use the water here if you pleased...
Good luck
For purifying the water a person could use a solar still but you need sunny days for that to work .
Unless you distill it the really is no way to get any of the contaminates out of the water from your roofing , dust , airborne particles , chemicals , bugs , and whatever else is suspended in the air that the rain is washing down through your system.
About the only thing you could use if for is for washing and bathing after just filtering the larger particles out of it.
How is a person going to keep it from freezing up in the winter?
I suppose that you could just melt snow to get water.
Back in the old days many of the old farm places had cistern systems that would collect the rain water from the building roofs.
It went into an underground tank like 5000 Gallons in size.
The ground temperatures would keep it from freezing up.
The old kitchens had a "hand pump" mounted into the counter top to bring it up into the house.
The windmill would pump the water up out of the well and into a large tank usually way up in the hayloft of the barn.
The water line would run underground to the house.
They used height or gravity for the water pressure.
Don't ask me how they kept it from freezing other than stacking the hay around the tank to insulate it.
Perhaps just normal usage of the water through it would keep it warmed from the fresh ground water.
I thought about doing this to my own property but use the white PVC and installing it underground and sloping the whole system so it runs naturally towards the tank and filtration system.
The tank would have to be buried at least 48" deep to the top of the underground tank. This way a person can have all the piping in the ground and just install diverter valves at each downspout location where it goes into the ground piping and also perhaps a separate tile system to dump the water someplace else away from the foundations of the house.
My next thought was going to be ,"what am I going to use all the water for" ?
I can't drink it unless it gets boiled and distilled and that takes some form of energy and or heat to make it happen.
I am not sure what is done in country areas in the US but here most farms use tank water gathered of the roof for household use. Been done here for over a hundred years; mostly galvanized iron tanks, plumbing and roofs. The filter was usually just a sieve of nail holes in a piece of gal iron. Very important to stop leaves, birds, possums and snakes from drowning in the tank and contaminating the water. Occasionally mosquitoes were a problem but the squeamish just boiled the water before drinking. The taps were a bit above the bottom so dust had a place to settle. Sounds rough but millions of our ancestors thrived that way.
Keep in mind that all our city drinking water is collected in open air reservoirs and water treatment is fairly basic. What keeps it pure is mostly the greater volume of water wrt the dirt.
Nevertheless, as others have mentioned, with the reclaimed plastic storage tanks, be sure you know the history of what they have had inside them if you are going to use them for drinking water. HDPE can absorb and hold some chemical contaminants for a long time.
Here is how the system works. We let the first rain wash away all the dust and dry leaves. We dont collect the first rain. After the first rain of the season, water from the channels is diverted into a Prechamber (much in the way the instructable here has done) but with a big bag filter in between. We change this cotton gauze bag every few days when it rains. Now in the prechamber at half the height a pipe is taken out and let into the main tank. This is to allow any sedimentation to happen in the prechamber itself instead of the main tank.
The pipe leadint to the main tank also has a metal gauze filter (i guess its basically a galvalized steel gauze bent info a hemisphere and held on the mouth of the pipe inside the pretank with the help of a wire.
Thats how we collect the rainwater. Its good for drinking and cooking and lasts us for the better part of the year.
This system only works well for drinking water if you have a metal roof.
My water comes from a garage roof with a pine tree that drops needles all over. I added a strainer but that only keeps the larger solid items out. The inside of the tank was lined with some sort of tan slime or mold after 1 season. I used a garden hose to try to rinse it out. I would never drink from it. We use it for watering the garden. The guy we got it from was quite adamant about us not drinking from it. He steam cleaned it but I think it was full of cow or pig urine before. These are used in farming, food, firefighting and all sorts of industries. I added an overflow joint and hose so it doesn't flood the ground where the tank is which is by the garage. I have an additional 50 foot 2" hose for overflow. I put the tank up on 2 layers of solid 4x8x16" concrete blocks for elevation and to keep it from settling into the dirt. Full up, these tanks are very heavy. The extra height provides a little more gravity pressure feed. I added an adapter to the outlet valve so I can connect a standard garden hose.
Use caution when using used tanks as you don't want to store drinking water in a tank used for holding something that could be poisonous. Tanks used for food stuffs Is probably OK.
If you don't want one used this site sells them as well as parts for used tanks, they are not cheap however.
http://www.jmesales.com/department/2575/1/IBCs-Totes-Tank-Accessories.aspx
Another place seems to have them cheap (relatively) but, do your research. http://www.ntotank.com/275gatota.html
I bought mine for $99 each from a local store that resells all kinds of stuff from bulk auctions.
These maybe much better but when I collected water in old milk jugs, they rotted in less than a year in the hot sun. Maybe you could tie a tarp over your awesome receptacles!
If you have not already ...you might want to add first flush divertors. That would help remove minute particles of pollution, dust and bird droppings from entering the tank.
oh yea, it will be a funny time when you get that tank filled with water
now you can sall rain water on ebay
