ESP-12F: Flashing AT Firmware
14,627
15
Posted in TechnologyArduino
Introduction: ESP-12F: Flashing AT Firmware
In this Instructable I'll show you how to flash the AT-Firmware on the ESP8266 ESP-12F Module.
For the hardware part you should check my ESP-12F ESP8266 Minimal Breadboard for Flashing.
I'll use here the official Espressif Flash tool in order to flash the Ai-Thinker Command Firmware and the Espressif AT Firmware.
Step 1: Install Flash Tool and First Run
The Espressif website had changed. You can find the Flash Tool now on Espressif Ressources page : https://espressif.com/en/products/hardware/esp8266ex/resources
I also put a copy here: https://github.com/flav1972/esp8266_ressources/tree/master/tools
Download the Flash Download Tools V3.4.4 (flash_download_tools_v3.4.4.zip).
  • Unzip it and run: ESPFlashDownloadTool_v3.4.4.exe
  • A text window will open and also a graphical UI.
Watch the text window for messages.
  • On the UI select ESP Download Tool.
The interface will open.
  • Select your right COM port.
  • Set Speed to 230400.
  • Keep the other info like on the screen capture
Step 2: First Connection to ESP82666
Press START on the UI.
Keep "FLASH botton" on the breadboard
When the text window shows "Connecting..." quickly press and release "RESET button" while keeping the FLASH button pressed.
You can try this several times in order to get the right timing. The text window will show "Connecting..." each 10 seconds.
Once connection is established will display some text like
Leaving...<br>com closed
pic path: ./RESOURCE/FINISH_S.bmp
The UI will show you in DETECTED INFO section the data about the chip.
32Mbit of RAM and 26 MHz cristall.
Step 3: Flash Ai-Thinker Firmware
You can find Ai-Thinker Firmware in this three places
Both zip files
AiThinker_1.5.4_AT_Firmware_DIO_8M_1MByte.zip and
At_firmware_bin1.54.zip are containing the same file that we need here.
Setup the flash-tool as folows:
  • flash AiThinker_ESP8266_DIO_32M_32M_20160615_V1.5.4.bin in position
    0x00000
  • keep CrystalFreq at 26M, SPI Speed at 40MHz
  • select SPI MODE: DIO
  • select Flash Size: 32Mbit
When are you ready press start.
As in previous step keep "Flash button" pressed and quiclky press and depresse "Reset" when Connecting is displayed.
Once connected the screen will pause for a while.
The flashing is showing the progress.
Once finished it will say "Leaving... comm closed" and it will display Finished green icon.
A little test:
run Arduino Serial Monitor at 115200 bauds.
Reset the ESP-12F.
AT+GMR
will show you the version of the firmware
AT+GMR
AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
OK
Step 4: Flash Espressif AT-Firmware
For flashing the official Espressif Firmware you can follow the instructions section 1.2 of http://espressif.com/sites/default/files/documentation/4a-esp8266_at_instruction_set_en.pdf. (The file is also attached here).
The firmware is part of the non-OS SDK.
There are several versions of the firmware:
In
ESP8266_NONOS_SDK_V1.5.2_16_01_29/bin/at/readme.txt and
esp8266_nonos_sdk_v2.0.0_16_08_10/bin/at/README.md there are the instructions for the memory mapping.
Step 5: Espressif AT From SDK 1.5.2 512+512 Memory Map
The readme sais for 32M and 512+512:
Flash size 32Mbit: 512KB+512KB
boot_v1.2+.bin          0x00000
user1.1024.new.2.bin      0x01000
esp_init_data_default.bin    0x3fc000 (optional)
blank.bin               0x7e000 & 0x3fe000
So open the ESP flash tool and set the files and flashing positions accordly. (Picture 1)
Press flash, reset and click download, release reset (as in Ai-Thinker flashing).
The flashing should start writting to flash (Picture 2).
When finished you will get something like Picture 3.
Open Arduino IDE.
Open Serial Monitor.
Set 115200bauds, Both NL&CR (if not already done).
Reset ESP.
Then enter AT+GMR command.
Version should be:
AT version:0.60.0.0(Jan 29 2016 15:10:17)
SDK version:1.5.2(80914727) compile time:Jan 29 2016 19:07:08
If you do AT+RST you should get also something like
ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 816, room 16 tail 0 chksum 0x8d load 0x3ffe8000, len 788, room 8 tail 12 chksum 0xcf ho 0 tail 12 room 4 load 0x3ffe8314, len 288, room 12 tail 4 chksum 0xcf csum 0xcf 2nd boot version : 1.2 SPI Speed : 40MHz SPI Mode : DIO SPI Flash Size : 32Mbit jump to run user1 don't use rtc mem data
Step 6: Save Download Tools Settings
When you leave ESP Download Tool a file named tool_config.txt is created in the same directory as the exe.
This contains your last config.
For further reuse copy the tool_config.txt to anothe file (eg tool_config1.5.2.1024.txt).
You can reuse this file by overiting your saved file to tool_config.txt before restarting the download Tool.
Step 7: Espressif AT From SDK 2.0.0 1024+1024 Memory Map
The readme sais:
### Flash size 32Mbit-C1: 1024KB+1024KB
boot_v1.2+.bin 0x00000 user1.2048.new.5.bin 0x01000 esp_init_data_default.bin 0x3fc000 (optional) blank.bin 0xfe000 & 0x3fe000
Set the files as in the picture but keep memory type to 32Mbit.
Flash it.
Arduino Ide should say:
AT+GMR
AT version:1.3.0.0(Jul 14 2016 18:54:01) SDK version:2.0.0(656edbf) compile time:Jul 19 2016 18:44:22
Step 8: Espressif AT From SDK 1.5.2 1024+1024 Memory Map
The Readme says:
After flashing version is:
AT+GMR
compile time:Jan 29 2016 19:06:50
OK
AT+RST
OK
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
  SPI Speed      : 40MHz
  SPI Mode       : DIO
jump to run user1
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Make it Move Contest
    1 Questions
    Hi! I am trying to download firmware to ESP 8266(ESP-12) wifi module through USB to UART converter using the minimal circuit from your website but it is continuously giving this error in download tool (though the tool is sensing the attached module as shown under detected info bar in the attached screenshot).
    I shall be very thankful to you if you could help me. Thanks in anticipation.
    28828591_618955268447958_6686637511462482040_o.jpg29497662_618938175116334_8061536519674376752_n.jpg
    did you tried:
    -When the text window shows "Connecting..." quickly press and release "RESET button" while keeping the FLASH button pressed.
    1 more answer
    Yeah I tried that but finally, one small swipe did the work that is of Rx and Tx. So now I am communicating with esp module while its Rx and Tx pins are inserted in Rx and Tx of USB to UART converter. Thank you so much for your guidance and this helpful tutorial.
    Fantastic! And thanks for making the files we need to flash downloadible. They and the instructions are not easy to find on the Expressif site.
    How do I find out if I have 512+512 or 1024+1024 on an 4MB memory chip? Is it perhaps the quad 1024 spec in the log?
    Kindest Regards,
    MJM
