ESP 8266 Nodemcu Ws 2812 Neopixel Based LED MOOD Lamp Controlled by Local Web Server
Published
Introduction: ESP 8266 Nodemcu Ws 2812 Neopixel Based LED MOOD Lamp Controlled by Local Web Server
About: I am an engineering student and i just love doing electronic (mcu's) and programming (C,C++,JAVA) based projects.
ESP 8266 Nodemcu Ws 2812 Neopixel Based LED MOOD Lamp Controlled Using Webserver
Step 1: Basic Idea
Hello guys in this instructables i made MOOD LAMP based on Neopixel LED Ring with Nodemcu ESP 8266 and the Lamp is controlled by webserver hosted by nodemcu on the device. So the basic idea to is create a web server by nodemcu and to access that local web server by phone/PC browser & then sending commands by that page to control Neopixels LED by that local web server & light up the Lamp in different colors with different brightness by sending commands from the interface hosted by local web server and there are different modes to see different pattern lights , so enjoy making your own neopixel based web server controlled MOOD LAMP
Step 2: Gather Your Components
Step 3: Circuit Preparation
The circuit is really simple all you need to do is connect the nodemcu Vin pin to Vcc of neopixel since we are using Vin pin of nodemcu for neopixel so don't use more than 5v as power for node mcu that's why i used usb cable supply then connect Gnd of nodemcu to Neopixel Gnd & Din pin of the neopixel to the D2 pin on nodemcu.
Step 4: Upload Code
Download the zipped code from the given link :-
https://drive.google.com/file/d/1QV6wmMxV9W_SGnshp...
then open it in ARDUINO ide & in the code set the neopixel pin to D2 ( whatever the pin of data of neopixel is connected to nodemcu) then number of pixels which mean the no of LEDs on your neopixel then imput your ssid of your router or mobile hotspot upload the code.
Step 5: Enclosure of Project
i made a box of cardboard to cover the electronics & the cap of LED bulb as a diffuser to make the light uniform in all direction, you can design whatever you like.
Step 6: Let's Test It
In the final step let's the cable then the nodemcu will look for the network of which it has ssid & pass in the code and if network is found it will connect , now get any device connected to the same network or use same mobile of which you are using hotspot and from the browser type the IP as 192.168.4.1 (mine is 192.168.43.72 because i have changed it if you haven't changed yours try the given outside this bracket) and if you wanna know your ip then connect nodemcu to the PC & then open serial monitor & you'll get the IP then access the web server using that ip from browser & change the color brightness & mode of neopixel fron the browser & enjoy your own light show from your own MOOD LAMP .For issues refer video for better understanding.
Thanks...
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    Nice I structable, thanks for sharing!
