Introduction: ESP32 Touch Camera
This is an idea about ESP32 and TFT screen, we can combine them to realize the function of a drawing board let us draw, and plug in the SD card to realize the function of digital photo frame to display beautiful photos. Now, we add a camera on this basis, and realize a simple digital camera, which can take pictures through the camera and save it in the SD card.
we integrate all modules and interfaces on the board, and achieve the above three functions by downloading programs to the board.
This board has many features:
- Integrated ESP32 2.4G WiFi and Bluetooth.
- Micro SD card slot on board.
- OV2640 is a 1/4 inch CMOS UXGA (1632*1232) image sensor manufactured by OmniVision.
- LCD 3.5 inch Amorphous-TFT-LCD (Thin Film Transistor Liquid Crystal Display)
hardware:
- ESP32 Touch Camera
(ESP32 3.5" TFT Touch(Resistive) with Camera:https://www.makerfabs.com/esp32-3.5-inch-tft-touch...
ESP32 3.5" TFT Touch(Capacitive) with Camera:https://www.makerfabs.com/esp32-3.5-inch-tft-touch-capacitive-with-camera.html )
- Micro SD card
- Type-C USB cable
software:
- Arduino IDE
Step 1: Connection
This is a complete circuit board, only need to plug in the SD card and power supply cable to use.
Step 2: Software Setup
- Install board: esp32. About the detailed of installation steps, please check the previous introduction: https://www.instructables.com/id/ESP32-Audio-Player/
- Install library: Adafruit GFX library.
Step 3: Code
We did some experiments with both screens and wrote two kinds of codes.Modify the code based on the touch screen that use the resistive screen to remove the NS2009 comment and the capacitive screen to remove the FT6236 comment before loading the code.
//Choice your touch IC #define ESP32_SDA 26 #define ESP32_SCL 27 //#define NS2009_TOUCH #define FT6236_TOUCH
- Drawing
You can get the code from here:
https://github.com/Makerfabs/Project_Touch-Screen-Camera/tree/master/touch_draw_v2
SPI_ON_TFT; tft.begin(); tft.fillScreen(ILI9488_BLACK); tft.fillRect(0, 0, 80, 40, ILI9488_RED); tft.fillRect(80, 0, 80, 40, ILI9488_GREEN); tft.fillRect(160, 0, 80, 40, ILI9488_BLUE); tft.fillRect(240, 0, 80, 40, ILI9488_YELLOW); SPI_OFF_TFT;
2.Modify the pen color
if (0 < pos[0] && pos[0] < 80) { draw_color = ILI9488_RED; } else if (80 < pos[0] && pos[0] < 160) { draw_color = ILI9488_GREEN; } else if (160 < pos[0] && pos[0] < 240) { draw_color = ILI9488_BLUE; } else if (240 < pos[0] && pos[0] < 320) { draw_color = ILI9488_YELLOW; }
- Digital photo frame
https://github.com/Makerfabs/Project_Touch-Screen-Camra/tree/master/SD2TFT
1.Fill in the picture name in the SD card
String img_file[5] = { "/1.bmp", "/2.bmp", "/3.bmp", "/4.bmp", "/5.bmp"};
2.Display image
int print_img(fs::FS &fs, String filename)<br>
- Take photos
https://github.com/Makerfabs/Project_Touch-Screen-Camra/tree/master/Camera_v2
1.Data transmission
TFT<--SPI--> ESP32 SD<--SPI--> ESP32 CAMERA--> ESP32--SPI-->SD
2.Data transcoding
void *ptrVal = NULL; ptrVal = heap_caps_malloc(ARRAY_LENGTH, MALLOC_CAP_SPIRAM); uint8_t *rgb = (uint8_t *)ptrVal; fmt2rgb888(fb->buf, fb->len, PIXFORMAT_RGB565, rgb); save_image(SD, rgb); show_log(0); heap_caps_free(ptrVal); rgb = NULL;
