Introduction: ESP8266-12 Blynk Wireless Simple Virtual Led
Picture of ESP8266-12 Blynk Wireless Simple Virtual Led
This simple project is to show how you can activate a virtual LED in Blynk.
Pressing the button turns on the virtual LED on the app Blynk, releasing the button turns off the LED
It will be useful for applications such as PIR sensor or reed sensor and many others.
Step 1: Materials
Picture of Materials
ESP8266-12 (esp8266-7, ...... , esp8266-12e)
button
10k resistor
power regulator 3,3v
Step 2: Connections
Picture of Connections
ESP8266-12
VCC +3,3v
CH-PD +3.3v
gpio13---- button (pulldown resistor)
GND ground
GPIO5 ground
Step 3: Blynk App
Picture of Blynk App
www.blynk.cc
store
app Blynk Apple Store
Blynk Google Play store
configure blynk
create new project ( use hardware model esp8266 )
generate AUTH TOKEN send E-mail TOKEN ( copy TOKEN in the esp8266 sketch)
in the app Blynk use Led
Step 4: Sketch
sketch
blynk library
to programming the ESP8266-12, I use ide arduino 1.6.5 and CP2102 3.3V USB To UART Serial Interface Module Adaptor ( do not connect the power of the CP2102 to esp8266-12).
SP8266 sketch change the sketch in the following lines with your data
char auth[] = "xxxxxxxxxx"; //insert here your token generated by Blynk
Blynk.begin(auth, "ssid", "password!"); //insert here your SSID and password
Step 5: Thanks
thanks
by catoplepa
AndersonL9 (author)2016-04-06
HI, can you show how to programming the ESP8266 with an FT232? Thank you
catoplepa (author)2015-11-08
Hi iolanda1
I'm glad I helped
iolanda1 (author)2015-11-08
Hey there thank you for this great info, this is the first time that works for me ,I couldn't find and example at the Blynk website but yours which works great once again thank you!!
About This Instructable
6,370views
25favorites
License:
More by catoplepa:ESP8266-12 blynk wireless simple virtual ledESP8266-12 blynk wireless temperature LM35 sensorESP8266-12 blynk wireless temperature, humidity DHT22 sensor
Add instructable to:
