NodeMCU ESP8266 12e With GPS & OLED Display
34,848
61
27
Posted
Introduction: NodeMCU ESP8266 12e With GPS & OLED Display
In this Instructable I will describe how to hookup a Ublox 6m GPS module and an OLED display to the NodeMCU or ESP8266-12e wifi module to display your current GPS location and other info.
Check out my Youtube Video describing this. Youtube Video
Step 1: Ingredients - What You Will Need
In this Instructable I will describe how to hookup a Ublox 6m GPS module and an OLED display to the NodeMCU or ESP8266-12e wifi module to display your current GPS location and other info. With a little extra programming you could use it to broadcast your GPS location to the internet using the wifi on the esp8266, and upload it to ioadafruit or another MQTT cloud server. Maybe attach it to your dog a see where and how much he roams around the yard!
Step One: The ingredients
1. You'll need an ESP8266 - e12 wifi module
2. An OLED display ($5- $10 from Ebay)
3. A Ublox 6m GPS receiver or similiar model
4. A breadboard and some jumper wires
Step 2: Hooking It Up
1. First place the ESP8266 on a breadboard
2. Connect a jumper wire from the Ground and Output VCC of the ESP to the power and ground rails of the breadboard.
3. Connect the Ground and VCC of the GPS and the Oled Display to the power rails of the breadboard. Make sure Ground is to (Ground -) and VCC is to the (Red +)
4. Connect the SCL Pin of the Oled display to the ESP D1 pin (the Yellow wire in the picture), and connect the SDA Pin of the Oled display to D2 pin (the Blue wire in the picture) These are your I2C communication connections.
5. Connect the TX pin of the GPS to the D6 pin of the ESP (the Blue wire), and connect the RX pin of the GPS to the D7 pin of the ESP (the white wire) These are your Serial communication pins. You could choose just about any data pins you like, but you will also have to make the necessary changes in the code.
Here is a link to a pinout diagram of the ESP-12e Board to assist you.
Acrobotic Pinout
Step 3: Upload the Code
First, I assume you have the Arduino IDE already installed (preferably 1.6.4 or later) and that you have installed all the necessary libraries such as: TinyGPS plus, Software Serial, and the Adafruit OLED display library. You can get these from Github.
If not, install the latest version of the Arduino IDE and the libraries first.
I also assume you have installed all the necessary drivers for your computer to recognize the ESP8266, if not Adafruit has an excellent tutorial here. Adafruit ESP8266 Tutorial This is crucial if this is your first time using the ESP8266
Next, go to github and download the code and run it in the Arduino IDE.
Enter your latitude and longitude into the area of code "Home_LAT =" and "Home_LNG=" below
Compile it and upload to your NodeMcu esp-12e, In the Arduino IDE be sure to select your correct board (ESP-12E Module in my case) and the Memory size - 4M(3M SPIFFS)
Go for a walk or drive and watch your GPS position update, remember to keep your eyes on the road.
2 People Made This Project!
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
20 Comments
I used your code with my nodemcu and neo-m8n. It's can compile and upload but nothing happen.
Same, everything works apart from the gps
Tthere is a problem in instructions about TX and RX connections, TX in GPS must be conected to D7, and RX in GPS must be conected to D6.
Hello, I´m doing everything, step by step, but when I´m finishing compilation, I got this error:
collect2.exe: error: ld returned 1 exit status
Could you help me?, thanks.
I resolved the problem reported, it was about library incomplete, the program compiles very well. But, there is a problem in instructions about TX and RX connections, TX in GPS must be conected to D7, and RX in GPS must be conected to D6. Thanks so much for the project and information published, it was so usefull.
When I use tinygps library i am getting this in my serial monitor please do help
I have surfed net and done many things but i could not correct it
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
can i add a sd card to log the data
Can this be used with an Arduino Uno, or is this project only compatible with the NodeMCU?
I have a hard time compiling this code, is there a way to publish it along with the libraries that you have used? I would be very grateful... :-)
