ESP8266
Published
Introduction: ESP8266
About: AWESOME PERSON
HELLO IT IS AN EASY TUTORIAL
LIST OF PARTS
  • ARDUINO
  • ESP8266
  • WIRES
  • USB CABLE
Step 1: CONNECT ESP TO ARDUINO
here we connect arduino to esp8266
serial connection with esp
using tx rx pins
by using AT conmmand
ESP CAN BE CONTROLLED
Step 2: Intro Esp
hi hello esp is an simple wifi circuit which help to access the internet
i will guide you this tutorial
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    3 Comments
    the ESP8266-01 (above displayed module) is a wee bit limited on I/O (since it only has GPIO0 & 2 only on the pins, but it itself, is a full-fledged MCU, with a built in 802.11B/G/N WiFi which can be configured to access point, or node (client or host).I don't think they got to finish their instructable, as page-2 seems to end abruptly. The 3.3V regulator on the Arduino, however, is not really that strong, and tends to brown-out on the ESP8266's draw requirements (300mA. the 1117 regulator only has a max output of 100mA), so it's better to use an external 3.3V power source. there are some hacks out there, if your hands are steady enough, to get 2 more GPIO's (can't remember their #'s, or find the link to the instructable), you can actually run a small web server to those 2 original pins, (I2C, or direct digital).
    That board looks like it would be really useful. Could you share some more about how you used it?
