ESP8266 Garage Door Opener
Published
Introduction: ESP8266 Garage Door Opener
!!!!!!!!! Warning it will oscillate if you fallow the other tutorials!!!!!!!!!!!
I tried the transistor and also using the opto-isolator connected to ground but both pull the ESP too close to ground, it shorts out and will keep resetting itself. For the others I tried the PNP transitor, and it pulls to much current and also keeps resetting the ESP.
A simple low cost wireless garage door opener, only a couple parts need to be purchased, and can be expanded to control up to two doors with only a couple lines of code change and another optocoupler added.
Step 1: Need to Flash ESP8266
go to
https://github.com/nodemcu
and click on nodemcu-flasher and download
fallow the diagram to connect the esp8266 to your usb to serial adapter
This adapter I found(ebay) to be easy to install and was able to find drivers without any problems.
USB 2.0 to TTL UART Module 5pin Serial Converter CP2102 STC Replace FT232
run the program and flash, dont worry about changing anything just open and flash.
Step 2: Now Program the Esp8266
You can use lua uploader, or Esplorer. Both work great and are ready to work with the esp
Dont forget the un-ground the gpio0 pin but keep everything else the same between the esp and the usb to serial
Upload the code below to the esp
--Garage Opener Code
wifi.setmode(wifi.STATION);
wifi.sta.config ( "2WIRE713" , "0369559266" ); wifi.sta.setip({ip="192.168.1.200",netmask="255.255.255.0",gateway="192.168.1.254"});
gpio.mode(3, gpio.OUTPUT);
gpio.write(3, gpio.HIGH);
-- A simple http server srv=net.createServer(net.TCP); srv:listen(80,function(conn) conn:on("receive",function(conn,payload)
--print(payload);
gpio.write(3, gpio.LOW);
tmr.alarm(0, 1000, 0, function()
end )
conn:send("Opening Garage");
end)
conn:on("sent",function(conn) conn:close() end)
end)
The line
this is your current wifi name and password needed to make sure the garage door opener is secure
and the line
this sets up the esp to be a static ip on my network so I dont have to guess what the ip will be
Step 3: Connect and Run
Go ahead and connect you esp with the above diagram and turn on.
make sure your phone is set to connect to your home network automaticaly
go to your web browser on your phone and go to the ip address you assigned it. in the code example it is 192.168.1.200
save it to your bookmarks once you varified it works and save a shortcut to you phones desktop and every time you click the shortcut it will open the garage.
Enjoy!!!
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    7 Comments
    DOES NOT WORK FIX THIS.. CONSTANT ERRORS:
    stdin:1: attempt to index global 'conn' (a nil value)
    > end)
    stdin:1: '<eof>' expected near 'end'
    > end)
    whatd you use for a powersupply for this? one of those mb-102 (i think) powerboard (with 3.3 and 5v out) things or something else?
    Just the converter and usbwall charger
    this is great, i think alot of people overcomplicate some of their projects JUST so they can use something like an arduino etc.
    i cant remember which it was but i was looking at one that really had no reason for a microcontroller at all. it was simply relay logic
    Nice Instructable, do you have a parts list for what is in your schematic?
    Thank you, you are the only person that likes simplicity. If you need any help with anything let me know and I will try my best to help. Simple life, Work smarter not harder!
