ESP8266 NodeMCU Connect to Groov IoT
Published
Introduction: ESP8266 NodeMCU Connect to Groov IoT
About: Share - Learn - Makers. Projects, Articles, #automation, #PLC, #Arduino, #IoT and More PDAControl
This time we will test the Groov platform, but what is groov? Is a solution (IIoT) created by Opto22for the visualization, control and monitoring of industrial equipment from pc, mobile devices, tablets, smartphones and smart tv. It supports SNAP PAC controllers, Modbus TCP / IP devices and other PLC controllers from other brands such as Siemens, Allen Bradley, Yokogawa, Panasonic and others through connection to OPC UA Servers.
This tutorial will show the Connection of an ESP8266 12E NodeMCU and groov.
Tutorial completo: PDAControl Español
Pruebas Plataforma Industrial Groov y ESP8266 NodeMCU
Full Tutorial: PDAControl English
Testing Industrial Platform Groov and ESP8266 NodeMCU
Step 1: Video : Connection Platform Groov With ESP8266 NodeMCU : PDAControl
Tests Connection Groov Industrial Platform IoT with ESP8266 12E NodeMCU Module
Step 2: Components and Materials Required for Testing
Components and materials required for testing
ESP8266 12E
Diodes led
resistors
Converter TTL -USB
Protoboard
Wires
Step 3: Complete Info
Arduino IDE
A strategy has been created in Arduino IDE for the ESP8266 module which allows I / O control and communication as Slave modbus TCP / IP, 2 registers (Holding Registers) have been assigned to interact with groov.
ADC Signal Conditioning (0)
You must be very careful when using ADC (0) pin ESP8266 12E, TOUT, ADC (0) or pin 6 are some names by which this input will be identified, its resolution is 10 bits from 0 to 1.0V maximum, We have created a circuit based on a voltage divider and a diode to limit the input voltage in parallel to our light sensor, photoresist or LDR.
More Info & Donwloads
More Info: Groov.com
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
