ESP8266 - WIFI Temperature Data Logger - MCP9808
Published
Introduction: ESP8266 - WIFI Temperature Data Logger - MCP9808
In this project we will build a simple, high precision, WIFI Temperature Data logger based on ESP8266 module and the MCP9808 chip, a ±0.5°C Maximum Accuracy Digital Temperature Sensor.
Features
• Accuracy:
- ±0.25 (typical) from -40°C to +125°C
- ±0.5°C (maximum) from -20°C to 100°C
- ±1°C (maximum) from -40°C to +125°C
• User-Selectable Measurement Resolution:
- +0.5°C, +0.25°C, +0.125°C, +0.0625°C
• User-Programmable Temperature Limits:
- Temperature Window Limit
- Critical Temperature Limit
• User-Programmable Temperature Alert Output
• Operating Voltage Range: 2.7V to 5.5V
• Operating Current: 200 μA (typical)
• Shutdown Current: 0.1 μA (typical)
• 2-wire Interface: I2C/SMBus Compatible
• Available Packages: 2x3 DFN-8, MSOP-8
For more details, please see MCP9008 Datasheet
Step 1: MCP9808 - a Tiny MSOP 8 Package But Great Features
Don't be scared by the MSOP-8 package, with a small MSOP to DIP adapter will fit great in our CBDB extension slots or any other DevBoard with a compatible DIP slot.
Step 2: What We Will Need
What we will need:
  • CBDB Board or any other ESP8266 module
  • USB adapter (take a look on Part 1 for details how to connect them together)
  • MCP9808 Module from above
  • For programming we will use NodeMCU, a LUA language interpreter implementation for ESP8266 and for uploading the driver and the software we will use the LuaUploader.
Step 3: Driver Implementation
General considerations:
This is for Tambient > 0°C only. Take a look in the MCP9008 Datasheet .
If you need it also on the negative temperature scale then you need to do some extra transformations as the temperature data is stored in the 16-bit read-only Ambient Temperature register Ta as 13-bit data in two’s complement format.
As MCP9808 has a I2C compatible compatible interface, building a driver for it in NodeMCU it's a pretty straigh forward process:
1. Init I2C bus/interface
          dev_addr = 0x1F,
init = function (self, sda, scl) self.id = 0 i2c.setup(self.id, sda, scl, i2c.SLOW) end
2. Read / Write to/from the desired register location
  • READ Register function
read_reg = function(self, dev_addr, reg_addr)
i2c.start(self.id) i2c.address(self.id, dev_addr ,i2c.TRANSMITTER) i2c.write(self.id,reg_addr) i2c.stop(self.id) i2c.start(self.id) i2c.address(self.id, dev_addr,i2c.RECEIVER) c=i2c.read(self.id,2) i2c.stop(self.id) return c end
  • READ Temperature function
readTemp = function(self)
h, l = string.byte(self:read_reg(0x1F, 0x05), 1, 2) h1=bit.band(h,0x1F) --check if Ta > 0C or Ta<0C Sgn = bit.band(h,0x10) -- transform - CLEAR Sing BIT if Ta < 0C h2 = bit.band(h1,0x0F) tp = h2*16+l/16 --END calculate temperature for Ta > 0 return tp end
Step 4: Web Server - First RUN
Save the code on ESP as 'web_temp.lua', restart ESP and run:
=wifi.sta.getip() -- find the IP Address where your Web Server will be dofile("web_temp.lua") -- Start the Web Server
It is supposed that you have done already your ESP8266 module WIFI setup. If not, forst run:
      -- One time ESP Setup --
wifi.setmode(wifi.STATION) wifi.sta.config ( "WIFI_SSID" , "PASSWORD" ) print(wifi.sta.getip())
Open your favorite Web browser and type your new Web Server IP address. If all OK, should look something like in the attached image.
Step 5: Automatically Start Program and WebServer at Power On/reboot
If you want the Web Server to start automatically when your CBDB module starts or reboots, then you neet to create and add some lines in your 'init.lua' file:
tmr.now()                     -- for debug only, you can skip it
wifi.sta.getmac()             -- for debug only, you can skip it
wifi.sta.getip()              -- for debug only, you can skip itnode.heap()
dofile("web_temp.lua")        -- needed to start Web Server and  Temperature logger
Save the code on ESP as 'init.lua', restart ESP. It should reboot and restart the program and reinitialize the Web Server.
Step 6: Conclusion
With integrated WIFI Modules life can become easier than ever imagined only few years ago. To have a nice temperature WIFI sensor with Web interface, accessible thru Internet from any Worldwide location, for less than 10 USD, that was something more that a dream.
For more details and more exciting ESP8266 Projects please visit : www.esp8266-projects.com
Step 7: First RUN
For testing, just save the code on ESP as 'mcp9808.lua', restart ESP and run:
require('mcp9808')                         --call for new created MCP9808 Module Driver
sda=2 --GPIO4 -- declare your I2C interface PIN's scl=1 --GPIO5 mcp9808:init(sda, scl) -- initialize I2C tp1 = mcp9808:readTemp() -- read temperature =print(tp1) -- print it
Step 8: Web Server Interface
If all ok, we can move to the next step, how to make the data available on the web.
For this one we will need to build our Web Server functions:
  • WEB Server
srv=net.createServer(net.TCP)
srv:listen(80, function(conn) conn:on("receive",function(conn,payload) print(payload) conn:send("HTTP/1.1 200 OK\n\n")
        conn:send("<META HTTP-EQUIV=\"REFRESH\" CONTENT=\"5\">")
        conn:send("<html><title>MCP9808 - Temperature Log Server - ESP8266</title><body>")
        conn:send("<h1>ESP8266 Temperature Log Server - MCP9808</h1><BR>")
        conn:send("Temperature   : <b>" .. tp1 .. "°C</b><BR><BR>")
        conn:send("Node.HEAP : <b>" .. node.heap() .. "</b><BR><BR>")
        conn:send("IP ADDR    : <b>".. wifi.sta.getip() .. "</b><BR>")
        conn:send("Node MAC   : <b>" .. wifi.sta.getmac() .. "</b><br>")
        conn:send("TMR.NOW    : <b>" .. tmr.now() .. "</b><BR<BR><BR>")
        conn:send("</html></body>")
        conn:on("sent",function(conn) conn:close() end)
end) end)
function readTMP()
mcp9808:init(sda, scl) tp1 = mcp9808:readTemp() print(tp1) end
  • TIMER - to establish how often we want the reading process to be done.
    -- read data every 1sec for direct web reading
tmr.alarm(0, 1000, 1, function() readTMP() end )
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    this is very nice, i'm working on a similar project myself.. i used to just upload to thingspeak and collect data there (tweet alarms as well). this new design will have its own webserver, maybe even an app soon. i switched to esp-12 because of extra gpios. thank you for sharing, i'll bother you with some questions eventually :)
