Introduction: ESP8622 Webinterface for Local Variables
Picture of ESP8622 Webinterface for Local Variables
This manual will show you how you can edit ( get /set) local variables and local values , from a browser.
benefit : no need to use uart and change the lua-code to change parameters , like eg : ssid pasword , or whatever you want to edit , in real time..
Tools needed.
Hardware :
  • ESP8622-01
  • usb to TTL adaptor
Software :
Testmovie :
here : youtube
Step 1: Load De Lua Code Into Your Esp
Picture of Load De Lua Code Into Your Esp
  1. download the code: here :
  2. open ESPlorer
  3. open the code
  4. edit your SSID and SSID pasword to yours
  5. press :"save to esp"
  6. hard reboot , restart your ESPmodule
Step 2: Start Up ESP and Your Browser
Picture of Start Up ESP and Your Browser
In the ESPLORER window you get the DHCP IP address from the ESP.
use this ip into your browser.
press GET , to see the initial values from the ESP to the browser.
press SET , to change the local values from the browser to the ESP
Step 3: Demo Video
code is written to use with firefox
i tested also in chrome , but chrome did 2times a get request. , so tweak the code to use with chrome.
or download firefox here.
Step 4: How the Code Works...
Picture of How the Code Works...
the local value is sended to the html-page , parsed out , and stored in the local.
also
the local is send in the ESP webserver , via a form-tag
local var1 = "initvar1"
the value is set into a input textform :
input type=\"text\" name=\"p1\" value=\"".. var1.."\"
parsed out
positiep1 = string.find(req_data, "p1")
valuep1 = (string.sub(req_data, positiep1+3, positiep2-2))
and saved to the ESP memory as local variable
var1 = valuep1
Step 5: Lua Code
-- v12345vtm youtube https://youtu.be/MzH8zR34x0Y
--https://www.instructables.com/editInstructable/publish/EDRHQW8IG415EAG
-----uart mode uart.setup(0,9600,8,0,1)
-- Your Wifi connection data local SSID = "yourSSID" local SSID_PASSWORD = "yourSSIDpassword" local rtctijd = "15:50"
local var1 = "initvar1" local var2 = "initvar2" local var3 = "initvar3"
local function connect (conn, data) webcode=" "; webcode = webcode .. " " webcode = webcode .. " " webcode = webcode .. "
" webcode = webcode .. " " webcode = webcode .. "p1,ssid:
" webcode = webcode .. "p2,passw:
" webcode = webcode .. "p3,time:
" conn:on ("receive",function (cn, req_data) --print("wat is dat hier") print (req_data) -- print("staat er hier iet boven")
if string.match(req_data, "p1") then
positiep1 = string.find(req_data, "p1") positiep2 = string.find(req_data, "p2") positiep3 = string.find(req_data, "p3") positieEnd = string.find(req_data, "HTTP/")
valuep1 = (string.sub(req_data, positiep1+3, positiep2-2)) valuep2 = (string.sub(req_data, positiep2+3 , positiep3-2)) valuep3 = (string.sub(req_data, positiep3+3 , positieEnd-2)) uart.write (0, valuep1 , "\r\n") uart.write (0, valuep2 , "\r\n") uart.write (0, valuep3 , "\r\n") -- = time-15-10-23-12-27-35-4
var1 = valuep1 var2 = valuep2 var3 = valuep3 --webfomtijd opslaan else -- print ("geen data in form ingevuld gewest of de browser vroeg zijn favicon.ico daarnet ook nog") end cn:send (webcode) -- Close the connection for the request cn:close ( ) end) end
function wait_for_wifi_conn ( ) tmr.alarm (1, 1000, 1, function ( ) if wifi.sta.getip ( ) == nil then print ("Waiting for Wifi connection") else tmr.stop (1) print ("ESP8266 mode is: " .. wifi.getmode ( )) print ("The module MAC address is: " .. wifi.ap.getmac ( )) print ("Config done, IP is " .. wifi.sta.getip ( )) ---gpio.write(led1, gpio.HIGH) end end) end
-- Configure the ESP as a station (client) wifi.setmode (wifi.STATION) wifi.sta.config (SSID, SSID_PASSWORD) wifi.sta.autoconnect (1)
-- Hang out until we get a wifi connection before the httpd server is started. wait_for_wifi_conn ( )
-- Create the httpd server svr = net.createServer (net.TCP, 30)
-- Server listening on port 80, call connect function if a request is received svr:listen (80, connect)
print ("uart.setup(0,9600,8,0,1) finished") print ("waiting for serial data....")
breagan22 (author)2016-05-01
Good job. The video is is great and shows how all this works. Nice!
DIY Hacks and How Tos (author)2015-10-24
Very interesting project. Thanks for sharing.
your welcome , this is my first instrutables , if you need more information , just ask.
About This Instructable
1,828views
27favorites
License:
More by strontzak:ESP8622 webinterface for local variables
Add instructable to:
