Introduction: ETX Telescope Rail Mount
Picture of ETX Telescope Rail Mount
The Meade ETX-80 and ETX-90 telescopes are great starter scopes, but the mount wears out pretty quickly. This Instructable will allow you to put this quality telescope on a standard rail mount.
Step 1: Defork the Telescope
I refer to others that have taken apart the ETX80. I believe the ETX90 is the same.
Here is a good video; you don't have to remove the base, so skip forward to about 28 seconds in or so.
https://youtu.be/KbUmbO1pfzQ
Step 2: Cut Heat Sink
Picture of Cut Heat Sink
I used a heat sink for my main part. The aluminum will be light and easy to cut. I cut off the sides after measuring. I also cut the length to fit under the telescope.
Step 3: Drill Heat Sink
Picture of Drill Heat Sink
Drill four holes in the one side of the heat sink. This will be used to anchor the telescope to the 'rail' (heat sink).
I filed it down a bit to avoid wear on the attachment point.
Step 4: Mount Rail (heatsink) to Telescope
Picture of Mount Rail (heatsink) to Telescope
Simply attach with zip ties (AKA swift tie). Plan ahead; I had to use two per end and therefore had to put the head under the heat sink. I put a piece of electric tape between the telescope and the heat sink to avoid a scratch and give it a landing place in case the metal isn't perfectly straight.
Step 5: Test It Out..
Picture of Test It Out..
Mount the whole shebang to your mount. In my case I have an Orion Skyview Pro GOTO equatorial mount. You will have to adjust your counter weight; in my case I had to reduce it quite a bit.
About This Instructable
375views
1favorite
More by Divejackdive:ETX Telescope Rail MountSuper cheap, super easy solar filter for your cameraRPI interchangeable lens camera from old SLR camera lens
Add instructable to:
