Introduction: EXO: Baby Don't Cry
Using Arduino to code part of the song, EXO's Baby Don't Cry.
Resources, references, and inspirations:
    1. Related course lectures from school.
    2. Music sheet: EXO - Baby Don't Cry
    3. http://pasted.co/d1a629c1
    4. https://www.arduino.cc/en/Tutorial/ToneMelody?from=Tutorial.Tone
    Step 1: Materials
    Step 2: Turn Bean+ Voltage to 5
    Near A3, A4, A5: move the switch toward A5, then connect the Bean+ to Grove Board.
    Step 3: Connect Vibration Motor, Magnetic Switch, and the Buzzer to Individual Wires
    Step 4: Connect Wires to Grove Board
    1. Vibration Motor to D0/D1
    2. Magnetic Switch to D2/D3
    3. Buzzer to D3/D4
    Step 5: You're Done!
    Take the magnet and put it on or touch the Magnetic Switch.
    Step 6: Code - EXO.ino
    * NOTE:
    * 1. Bean needs to be on voltage of 5 (5v)
    * 2. notes array contain names of available tones, not the actual tone for the song
    * 3. Vibration Motor doesn't always stop when magnet is removed from the Magnetic Switch --> 99% of the time
    * 4. Additional idea or WIP for Vibration Motor: able to vibrate along with the tones
    * Material list and links
    * 1. Lightblue Bean Plus (+): http://store.punchthrough.com/collections/bean-fa...
    * 2. Grove Board: http://store.punchthrough.com/collections/bean-fa...
    * 3. Vibration Motor: http://store.punchthrough.com/collections/bean-fa...
    * 4. Magnetic Switch: http://store.punchthrough.com/collections/bean-fa...
    * 5. Buzzer (Starter kit): http://store.punchthrough.com/collections/bean-fa...
    * 6. Magnet: http://store.punchthrough.com/collections/bean-fa...
    int speakerPin = 3; //Buzzer: D3/D4
    // int touchSensor = 1; //Touch Sensor or Light Sensor: D0/D1
    int magneticSwitch = 2; // D2/D3
    int vibrationMotor = 0; //D0/D1
    int length = 107; //number of notes
    char notes[] = "fecffecffabffceagfeffecffecffabffceaaaaaddcfg fgaaaagg aaaaddcfg fgaaafgabaaceeeeccaa aceeeeeccadc dcgggg c"; //a space is a rest, so it won't buzz at that point
    int beats[] = {1,1,1,3,1,1,1,3,1,1,1,3,1,1,1,1,1,1,1,1,1,1,1,3,1,1,1,3,1,1,1,3,1,1,1,2,1,1,1,1,1,2,1,2,2,2,1,1,1,1,1,2,1,3,1,1,1,1,1,2,2,1,2,2,2,1,1,1,1,2,1,1,2,1,2,1,1,2,1,1,2,1,2,1,2,1,1,1,1,1,1,1,2,1,2,1,2,2,1,2,2,1,1,1,1,2,1};
    int tempo = 150; // Speed at which the notes (and beats) are played
    ////variables for calculating tone
    // int period;
    // int toneFrequency;
    struct color { uint8_t r; uint8_t g; uint8_t b; };
    void playTone(int tone, int duration) {
    int sensorState = digitalRead(magneticSwitch);
    if (sensorState == 1) {
    for (long i = 0; i < duration * 1000L; i += tone * 2) {
    // Play tone through Buzzer
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
    // Vibrate through Vibration Motor
    digitalWrite(vibrationMotor, HIGH);
    } //for
    } else {
    // Vibrate through Vibration Motor digitalWrite(vibrationMotor, LOW);
    } //for
    } //else
    } //playTone
    void playNote(char note, int duration) {
    char names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C', 'D'}; //capital C for high c
    int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956, 587}; //http://pasted.co/d1a629c1
    /*Tried to find ways to "create" more tones than the ones already present, such as high and low a instead of just the regular a*/
    // For each of the different names, other than the general note names, corresponding tones are presented //char names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C', 'D','E','F','G','A'}; //capital C for high c
    //int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956, 587, , , , }; //http://pasted.co/d1a629c1
    //char names[] = {'C7', 'D6', 'E5', 'f', 'g', 'a', 'b', 'C', 'D'};
    //int timeHigh = period / 2; // Calculating the tone using period value //int tones[] = {2093, 1175, 659}; //regular c = C7, lower c = C8, and higher c = C6 and so on; tones from: https://www.arduino.cc/en/Tutorial/ToneMelody?fro...
    //colors for notes color
    colors[] = {{255, 0, 0}, {244, 244, 66}, {66, 182, 244}, {0, 255, 0}, {143, 66, 244}, {244, 66, 241}, {146, 244, 66}, {0, 0, 255}, {64, 123, 235}}; //number don't actually matter, just each one need to be a different color
    //set bead LED color
    for (int i = 0; i < 9; i++) {
    if (names[i] == note) {
    Bean.setLed(colors[i].r, colors[i].g, colors[i].b);
    playTone(tones[i], duration);
    Bean.setLed(0, 0, 0);
    void setup() {
    Serial.begin(57600);
    pinMode(magneticSwitch, INPUT);
    pinMode(vibrationMotor,OUTPUT); //vibration motor has to be 0 or lower pin
    pinMode(speakerPin, OUTPUT);
    void loop() {
    Serial.println(sensorState);
    for (int i = 0; i < length && digitalRead(magneticSwitch) == 1; i++) { //if we reached the end the song will stop playing
    if (notes[i] == ' ') {
    Bean.setLed(0, 0, 0); delay(beats[i]*tempo); //rest
    } else {
    playNote(notes[i], beats[i]*tempo);
    } //pause between notes
    delay(tempo / 2);
