EXTRA HANDS FOR SOLDERING - OCTOPUS
5,564
261
19
Published
Introduction: EXTRA HANDS FOR SOLDERING - OCTOPUS
A extra hands (helping hand), also known as a third hand, is a type of extremely adjustable hands to hold materials near each other so that the user can work on them.
Step 1: MATERIALS USED
  • Piece of wooden block
  • Wood sticks with square cross-section (10x10mm)
  • Alligator clips - 4 pairs
  • Flexible and stiff wire of preferable gauge
  • 0.5 W LED - 2 nos
  • SPST switch
  • 9 V battery with snap
  • Wires, Screws and other consumables.
  • Tools - Fixtures, Cross-cut saw, Drill, Angle Grinder, pliers, Cutters, Screw Drivers.
Step 2: Mark & Cut a Slot With Cross-cut SAW
  • Use a wood marker or Mica cutter to make impression in wood.
  • Then use Cross-cut saw to make a slot just enough for 4 wires to pass.
Step 3: Insert Wires and Secure Them With Tacker-gun
Step 4: Connect the Alligator Clips to the Free Ends
Step 5: Solder Lead Dispenser
Mark and Cut three pieces as shown in the pictures
Step 6: Drill N Screw
Make hole and then Screw as shown
Step 7: Slide the Spool in and Screw It to the Wooden Block
Step 8: Winding Over the Syringe
Step 9: Screw and Chop Off Its Excess Using Angle Grinder With Cut-off Disc
Step 10: 0.5W LED's in Series
Step 11: Finishing - Light
Step 12: That's All!! Work With Caution!
Step 13: Optional - De-soldering Wick Holder
Step 14: Optional - Guide for Solder Wire Feed
Step 15: Optional - Holding Fixtures
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    19 Comments
    looks good but soon the build will need replacement bcz these wire can take the load. i had made this same design years ago . but good project
    hmm. may be in future it may need replacement not soon. since it can hold my pliers.
    dats really good i see your wire quality is better which wire did u used ?
    (I don't even know the gauge of the wire)I just went to a hardware store and paid 5 rupees for 1 meter of wire. I suggest gas welding filler rod which will be far more better than this.
    i hope to see a new better version later .one suggestion use flux cored solder rather than the syringe . will make it look good.
    Glad to see your interpretation! This is very well done! A much more permanent solution than mine, that's for sure. I think I'll follow your lead this time, and try to recreate this to my needs.
    I've needed one of these doing even the simplest of soldering jobs. I'll certainly make one (when I get around to it of course. XD)
    Hi, Ningarooster. Please do post the pictures here when you're done.
    Wonderful!
    Such an orderly, effective build, made from mostly reused materials.
    I love the rugged, utilitarian look!
    Looks awesome but my only question is the purpose of the syringe?
    looks like it holds the Flux
