3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Eagle-ize Leevonk's PIC protoboard
Eagle-ize Leevonk\
I like Leevonk's PIC development board; here it is re-done in Cadsoft
Eagle, with a couple other modifications to make it simpler/cheaper
Step 1Redraw the board and schematic
redraw the board and schematic
There's not a lot TO this instructable; it's pretty much just CAD files for a
modified version of Leevonk's instructable.
7 comments
Sep 27, 2008. 5:40 AMcollard41 says:
where are the current limiting resistiors there?
Aug 5, 2008. 5:54 PMSgtWookie says:
Nice. I've taken your Eagle files and cleaned them up a bit, along with adding individual resistors for each LED. Unfortunately, I don't know how to attach files. But if you send me an Email, I'll send you the source files. I can be found on AllAboutCircuits.com. SgtWookie
Jul 6, 2008. 2:06 AMPaulCo says:
I'm designing solar water/heating system for my house going to program & use pic/avr this just what i needed loads of thanks for the good work it will be well used
Oct 17, 2006. 10:51 PMblueroomelectronics says:
I too have been working on a pair of prototyping boards for PICs. One simple version uses the 16F88 (Firefly) and the other more complex version (2x16LCD, 4x3keypad) uses the more common 16F877A (Dragonfly) (and soon the 16F887). You can view the beta schematics on the updates section of my site. I've used RS485 in both with a simple RS232 to RS485 adapter (two 1k resistors and a DE9) www.blueroomelectronics.com One comment on your design is not using a single 470 resistor for 8 LEDs, a better solution would be a 9pin 8 resistor 470ohm SIP.
Jul 24, 2006. 8:00 AMPromethean says:
Hey! This is sort of the type of thing I'm looking for. I'm new to microcontrollers though, and could use a little direction on what may be required for an idea I'm trying to implement: A small, low powered text reader. I know the basic constraints I'd like on it, but have little idea of how to implement it except that PIC or Atmel may be a good way to go. The PCB and MCU needs to be able to support/drive: 1x16 Character LCD 256kBytes (or more) of storage space for text files Interface to load/erase data-- parallel, serial, usb-- doesn't matter which basic control/tact switch for start/stop etc. Could this board design here support that? Zilog also has cheap devkits ($40) for the Encore! line, but Atmel and PIC seem to have much larger communities to seek guidance from. Thanks for any help you can give!
May 31, 2006. 9:52 AMleevonk says:
wow, I'm flattered. good work with the mod :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
156
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
