3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ear bud case from a contact lens case
Ear buds are a wonderful way to connect your ears to your mp3 player but they have an awful tendency to turn themselves into knots that only a mathematician could love. Thankfully my wife's terrible vision has provided me a way to avoid those mathematically intriguing knots. Below is a simple way of turning extra contact lens cases into ear bud cases.
Step 1Cut the contact lens case
Remove the caps from the lens case, then cut a small slot in each bowl (see the second picture). The amount of material you need to remove will depend on the size and design of the "handle" portion of your ear buds. The last image in the Instructable shows some white buds that needed a longer thinner slot than the black ones. The slot should be big enough to allow the bud to rest entirely in the bowl of the lens case. If it rises above the lip of the bowl, then the caps will not screw on properly.
The easiest way to cut the cases is to heat an exacto knife in flame. If you don't use heat then use a very sharp blade and go slow. The plastic is a little brittle and is prone splitting if you apply too much pressure.
28 comments
Mar 27, 2011. 3:39 PMWehrdo says:
Wasn't this in Popular Science as a 5 minute project? Because I made one after reading about it in there. I use it every day, so if it was your idea, thank you very much! It has kept my earbuds working for three years now.
Apr 13, 2009. 8:40 AMEPL says:
yea i used to wrap the ear buds around my ipod really tight and the thing that connects the ear buds to the ipod ripped and the wires were exposed.
Mar 4, 2009. 8:55 PMcturtle says:
This is a great use for all those free cases I keep getting. I used the same method as hot-fresh-rider for my Skullcandy Ink'd ear buds.
Feb 24, 2009. 9:48 PMKillerPanda says:
good idea, seeing as i have several of these lying around somewhere with no use and i always end up destroying any ear bud or headset i come across. 4.5 stars =)
Feb 26, 2009. 7:34 AMsabbott says:
this is great! I've been trying to think of some way to store these things more effectively, just love it. Thanks for posting.
Feb 26, 2009. 7:45 PMudinho says:
I think that this is not so good for these phones which have a "handle portion". Depending on where they're stored, it could damage the earphones.
Feb 26, 2009. 12:55 PMHailDanzig says:
And I just threw a couple of those away! Good idea. :)
Feb 23, 2009. 12:17 PMhot-fresh-rider says:
this took me only 30 minutes, then 15 minutes fiddling with the photos in paint.net LOL _
Feb 24, 2009. 9:03 AMhot-fresh-rider says:
the stress of being rewound is less than being chucked in my pocket ! the wire sits in a V wedge right next to the cap. If i hadn't cut this notch then screwing the cap down would damage the wire. awesome instructable btw - because I realised "hey wait a minute, instead of just reading this one, I could actually do it now!" like i'm with so many other instructables. recommend Koss plugs btw, esp "the plug" haven't tried the "spark plugs" yet but I imagine they are much the same.
Feb 24, 2009. 1:10 AMchaitanyak says:
fantastic idea!!
Feb 23, 2009. 11:41 AMAudey says:
AHH; I tried it and then the conditioning solution wrecked my headphones and my headphones destroyed my contacts! DAMN!
Feb 23, 2009. 3:28 PMPatented says:
Hahaa! XD
Feb 23, 2009. 11:28 AMhot-fresh-rider says:
*snap* we have the same spare contact lens case. Just bought some KOSS KEB 24's and need somewhere nice to keep them.
Feb 18, 2009. 2:09 PMmettaurlover says:
actually, the indents were intended to reduce plastic needed to make the cases, but unintentionally made a perfet place to wrap an earbud cord.
Feb 19, 2009. 2:47 PMmettaurlover says:
yep. this is a method of reducing the actual amount of plastic using while still keeping the weight of the divider.
Feb 22, 2009. 5:54 PMmettaurlover says:
i may be crazy, but i know what i'm doing. which, in fact, is worse than if i didn't know what i was doing. the only thing worse than a crazy kid who doesn't know what he's doing is a crazy kid who knows exactly what he's doing.
Feb 18, 2009. 4:13 PMChrysN says:
Very clever, so having terrible vision is not all bad.
Feb 18, 2009. 3:16 PMgoodgnus says:
Not bad, not bad!
Feb 17, 2009. 6:10 PMPSPerson says:
never thought of doing that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mowdish
