Introduction: Earthquake Detector
This is a Earthquake Detector where i have added a led useing tx and 3.3volt. The led is hidden under the blue wire. Here's how i connected the circuit. 3.3volt to + of the board then digital tx1 to - ground of the board then plug in your LED with the cathode being + and anode being -  A0 to + and ground to - of board run a jumper from ground to the 220-ohm resistor and then run a jumper from the + to the 220-ohm resistor and put a rectifier diode in front of the resistor like the picture shows run 2 more jumpers inline with the resistor and the diode and hook your piezo speaker up with the red wire being + and the blue being - in the ardino program use the serial monitor to see the detector work tap the piezo and you will see this #. Here is the code        start here--------------------->     /*
Earthquake Detector
Sensing the tremors on a surface
Fritzing.org
This script will sense the tremors on a surface and output it in the serial monitor.
inspired by
http://todbot.com/blog/2006/10/29/spooky-arduino-projects-4-and-musical-arduino/
float tremor;                             // stores the analog value
int sensorPin = 0;                        // pin where the sensor is connected to
void setup()
  Serial.begin(115200);                     // initialisation of the serial connection
void loop()
  tremor = analogRead(sensorPin);    // reading analog sensor value
  if (tremor>0){                     // if tremor is sensed
    for (int i=0; i       Serial.print("#");
    Serial.println("");
  delay(0);                             // just wait a little
