Remove these ads by
Signing UpStep 1: Tools and Materials
(x1) 9V Relay (Radioshack Catalog #: 275-005)
(xvar) jumper wires (Radioshack Catalog #: 276-102)
(x2) Heavy duty 9V battery clips (Radioshack Catalog #: 270-324)
(x2) 9V batteries (Radioshack Catalog #: 23-866)
(x1) Prototyping PCB (Radioshack Catalog #: 276-170)
(x1) Piezo Buzzer (Radioshack Catalog #: 273-080)
(x1) 5K Ohm Potentiometer (Radioshack Catalog #: 271-1714)
(x1) Potentiometer cap (Radioshack Catalog #: 274-415)
(x1) 470 Ohm Resistor (Radioshack Catalog #: 271-1317)
(x1) 3" diameter acrylic tube
(x1) Magnet (Radioshack Catalog #: 64-1888)
(xvar) lamp-pull ball-chain
Tools:
Solder
Soldering Iron
Wire Snips
Hot Glue Gun
I used a laser cutter to make my own personal enclosure, but one could easily modify a pre-made project enclosure to suit the needs of this project.
Visit Our Store »
Go Pro Today »
http://eqseis.geosc.psu.edu/~cammon/HTML/Classes/IntroQuakes/Notes/seismometers.html
The easiest way to do this is to have a fairly heavy weight on the end of a coil spring. This will increase the sensitivity to lower frequencies. The other thing to do is to have some sort of damper like a paddle in oil. This might reduce non-earthquake vibration detection like trucks and people walking around.
You could do some of this electronically with filters.
Years ago I built a motion sensor similar to the samples we.
Can you please show the circuit diagram clearer? FULL
To compare it with mine
THANKS
Anyway, I was just lounging and enjoying the feel of the water when I noticed the water started to slowly sway side to side! I wasn't moving at all, and I couldn't understand what was going on at first. Since I live in a tectonically "stable" part of the planet, it took a few seconds to hit me that it was an Earthquake - a very mild one.
Since then I've always wanted to build a detector / data collector.
Not sure if you have this already - here's a link the the USGS Earthquakes data pages
http://earthquake.usgs.gov/earthquakes/
Thanks for some ideas on How-To.
Is this kind of just a motion sensor 'switch', rather than a detector? Can you get a reading from this to log the strength of a quake / tremor, or is the relay just turning on an earthquake alarm for nearby people.
