3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easier Kosher Flour Sifter (Bug Checker)
Check out the full article here: http://frumhacks.blogspot.com/2008/07/my-wife-thank-god-is-great-cook-and.html
My wife, thank God, is a great cook and wonderful baker. (really thank God because coming from my mother’s home anything less than great would have been a serious problem) But, as anyone living or spending time in Israel can tell you, baking in Israel can be a pain, not just because of the Celsius/Fahrenheit issue, nor the ounces, grams, mili, cups, kilo, etc. issue. The biggest pain of baking in Israel is the flour checking. Unless you are lucky enough to find pre-checked, vacuum sealed flour you are gonna be stuck sifting flour to check it for bugs.
Now when I say ‘pain’ I mean for me, I am usually the one who usually ends up sifting the flour, because I am the one who does most of the eating. Now as I am sure you are aware the conventional way of sifting is no picnic. In fact it is more like panning for gold than anything else. You have to put some flour in the sifter and shake it back and forth until the flour flows through the holes and you are left with clean, Kosher flour. It is not a fun job, and not a quick one.
On my mother’s last visit to Israel she brought a gift to our apartment. A flour sifter. No, not the kind you use to sift flour to make it Kosher, they don’t have those in America, but the kind you use to aerate flour for some random recipes. Being that we have never encountered such recipes, we never used the thing (sorry mom, you know she is reading, I am her baby).
Until Now.
Goal: Build an easier sifter to get bug free, Kosher flour.
Things you will need:
  • 1 Israeli 'panning for gold' flour sifter (Badatz Certified, of course)
  • 1 American 'flour aerator' sifter
  • A permanent marker
  • Pliers (needle nose and regular)
  • Hot glue and hot glue gun
  • A carpet knife (X-acto knife, or whatever)
  • Masking tape
  • Scissors
  • Screwdriver
  • Duct tape
  • Some flour
Step 1Disassembly
Disassembly
Look into the top of the sifter, you will see a bent piece of metal that holds the assembly together (see pic). Take your needle nose pliers, get in there and bend that sucker back so you can remove the top two pieces of the assembly. Use your needle nose pliers to carefully pull out the top two pieces. You need to be firm and gentle so as not to tear the screen, but don't be afraid to pull hard.
14 comments
Jul 7, 2008. 12:55 PMgkimber2 says:
Isn't there a risk that the agitators will actually grind up the bugs into pieces small enough to pass through the fine mesh? I don't keep kosher, so I don't know if this is a problem - I'm just asking.
Also -
In the USA, you might consider using silicone sealant that is FDA approved for food contact instead of hot melt glue. I don't know if there is such a thing as holt melt glue approved for food contact, but I have never seen it in my (limited) experience.
Not all silicone sealant is FDA approved for food contact, but this will be listed on the label somewhere in *very* fine print.
Aug 31, 2010. 2:52 PMatlantis43 says:
Actually, in America there are plenty of insect eggs & larvae in flour. If you dont use flour quickly, and do not refrigerate it, you will sooner or later always find them squiggling around in the surface of the flour. They look lovely when you find them. It always surprises me that flour can be "strictly kosher" at all, in view of the fact that insect eggs must almost surely always be present in the flour for this phenomenon to occur. This can, of course, be excused by simply saying that we can't see them, but then we must compare this to the recent rabbinical ruling in New York City that said that the tap water in the city must be filtered in order to be considered kosher after it was discovered that there were minute crustacea (shellfish) present in the water, as seen under a microscope.
Jul 7, 2008. 11:03 AMKiteman says:
That's a really nice project - I didn't know that the sifting was important, live and learn, eh?
Aug 24, 2010. 12:22 AMYnonk says:
http://www.koralek-almog.com that company has many flour sifting solutions for big and small bakeries. also in USA it is clear now that flour sifting is needed. Koralek installed few flour sifting systems in NY and insects were found. after all the world today in not cold like in the past...
Dec 3, 2009. 5:54 AMHollyHarken says:
I have a battery operated flour sifter that I bought years ago in some local store that isn't in business any more.  I can't find any thing on the sifter that says what brand it is or who makes it.  It runs on a C size battery and has only one screen that screws on and off for cleaning.  You might want to check the web for a similar flour sifter.
Also you should be able to bend the center post back with a flat head screw driver and a hammer.  Tthat will eliminate the use of glue.  You aren't adding that much thickness to make it hard to bend the center back into place.
Jul 8, 2008. 12:40 PMshooby says:
What 'bugs' in particular could one find in the flour? There are a lot of kosher insects, and several thousands of insect species are eaten worldwide (on purpose).
Aug 6, 2008. 4:33 PMUltraMagnus says:
only certain groups know which ones they are? it seems to be pretty much common knowledge....
http://en.wikipedia.org/wiki/Kosher_locust
Aug 7, 2008. 12:40 AMshooby says:
Shou? Which group?
Jul 8, 2008. 6:16 PMburningsuntech says:
Why not just keep the flour in the freezer where the insect larvae remain dormant and the flour lasts much longer. Or am I missing the point?
Jul 8, 2008. 8:54 AMmbtria says:
I don't sift for the bugs, but rather for volume consistency. I have found that shaking the flour in a strainer or sieve is much more efficient than any hand held mechanized sifter.
Jul 7, 2008. 6:38 PMtoklatkate says:
Not only very instructable, but with humor, also.
Very nice job.
toklatkate
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:allfortheboss
