3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easier Precision Miters on a Radial Arm Saw
A nicely fitting miter joint is very rewarding.  Radial arm saws allow the user to swing the saw arm 45 degrees left or right to cut miters.  It seems like a good system until you begin to use it for something precise, like a picture frame.  Swinging the arm to the right allows a good view of the material and works pretty well.
Step 1The problems appear
The problems appear
When you need to swing the arm to the left there is no table  remaining for material support to the left of the blade.  The operator cannot see any marking lines on the material and he may need to reach under the motor to secure the material against the fence.
7 comments
Jan 30, 2012. 11:37 PMAk-49 says:
Just a heads up... Not sure if your radial arm qualifies, check:
http://www.cpsc.gov/cpscpub/prerel/prhtml01/01031.html
The safety of a Free GUARD is a great thing!!!
Ak-49
Dec 15, 2009. 6:06 PMrimar2000 says:
Yes, Phil, miter cutting is frustrating. One is sure that the cut is correct, until one try to connect all parts...
Your method is perfect, the parts MUST connect at 90 degrees, even if the cutting angle isn't exactly 45 º.
Dec 16, 2009. 4:23 AMrimar2000 says:
HAHAHA, it's true!  I always went out winning 3 to 1, then!
Dec 15, 2009. 2:41 PMzieak says:
Thank you!  I get frustrated with mitre cuts.  I just finished trim on 12 windows... The only drawback to this is when you're trying to cut a long or heavy piece it is more difficult to support.  But I'm sure i can rig up something!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
