Introduction: Easiest Knife Paracord Grip
The easiest way to grip a knife/machete with paracord.
Step 1: Items Needed
This is what i used-
http://www.amazon.com/Cold-Steel-Kukri-Machetes/dp/B00CHTUJUS (Kukri)
http://www.amazon.com/Rothco-550-Pound-Commercial-Paracord-100-Feet/dp/B000S5ODOQ/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1391749117&sr=1-1&keywords=tan+paracord (Paracord)
You'll Need-
- Multitool
- Lighter
Step 2: String the Paracord Through
First start by stringing the paracord through the hole at the bottom of the knife. If you don't have this hole you can drill into your knife or wrap the cord around the bottom of your knife.
-String paracord through
-Leave about 1/2 inch paracord more than the grip
Step 3: Wrap the Paracord Around.
Then wrap the paracord from the other side of the hole around the knife. Keep wrapping until your near the end of the grip
Step 4: Tying the Knot
once your near then end of the grip leave 1/2" of paracord sticking out. Then tie the remaining pieces together with a simple square knot.
Step 5: Finshing
For more strength melt the knot together using a lighter or use a little electrical tape to secure it. Then cut off the excess paracord using you multitool or scissors.
Step 6: Done
Quick and Easy Paracord Grip
Paracord Contest
