Easily Adjustable Hammock Tarp and Gear Ridgeline
 by axman6
I've been looking for a way to set up my new ENO ProFly hammock tarp, and had previously come across an article showing a nice way to hang one and make it easily adjustable. It didn't quite meet my needs however; I wanted somewhere to hang my gear above me under the tarp while I slept and also get the ridge line set up ASAP so I could get my gear off my back/the ground, and get it covered as quickly as i could.
I've come up with a way that's really fast to set up, especially if you know your knots. If you don't, you can substitute almost all knots with some form of hardware if you prefer, but it's really worth learning the knots to reduce gear. They're all also useful in many other places (for example, I use the round turn and two half hitches to tie my guy lines to my pegs).
For this setup, you won't need very much gear:
* 10m (33ft) of kernmantle cord (rock climbing rope). I use 5mm rated at 6KN (600KG static load), and it's a good idea to not use cord much weaker than this. There is actually a hell of a lot of force put on this rig to keep it all taught. 10m leaves me qith quite a bit spare, but I woudn't go below 8.5m
* Several small karabiners. The ones I use in the pics are 600KG rated ones from Kong, but as long as they'll easily cope with the weight of the gear you're hanging, you'll be fine.
* A (hammock) tarp. I use an ENO ProFly I bought on eBay. The nice thing about this fly is that it comes with tensioners attached to the guy line attachment points, making setup easier: you can just loosely tie the guy lines then tension everything once it's all positioned.
* Tent pegs. I use some made my DAC, they're super strong and light. I won't be showing the tarp pegged out, I assume that's too obvious to bother with.
* Hammock (Optional). This setup will work just as well for someone who's lightweight camping with just a tarp instead of a full tent.
The image below shows the final setup, without the pegs (because I was too lazy and kneeling on damp ground in jeans is no fun). My pack is hanging under the tarp so I could do a lot of this setup in the rain and keep it dryish.
Step 1: First tree
The first step is to attach the 10m of rope onto one of the trees. I use a double bowline because I'm a knot geek, but a single bowline or round turn and two half hitches will work fine. The latter is a good idea because it will distribute the load around the tree a bit more evenly meaning it's less likely to damage the bark and kill the tree, but it does use more rope. I find the bowline doesn't pose a risk to the tree.
There's not much need to be too cautious about how big the loop around the tree is, as long as it's not tight around the tree. The smaller the loop, the more force is exerted on the rope.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
