If you dropped or otherwise damaged your camera, these instructions may or may not work.
Depending on your camera style, this method may or may not work.
If you're lucky, there is just a grain of sand or dirt stuck in the lens.
I came up with this quick and easy method over a year ago when the lens jammed on my girlfriends Nikon S210 - the camera is still working perfectly!
I am not responsible if you damage your camera while attempting to follow these simple instructions!
Remove these ads by
Signing UpStep 1Step One
Scotch Tape.
Camera.
Tear off a piece of scotch tape about three inches long.
mostly when digital camera lenses fail to open its because of a broken {or jammed}tooth on one of the small plastic gears inside.
this repair will not make the situation above any worse.
when it catches again if its able to home the lens properly then it will work for a while until it strikes the same bad patch again.
usually the repair guys will replace the entire mechanism and in some cases the whole camera.
good idea.
I would guess that if a camera is worth less than $200 it's not worth paying to fix.
