Easily Mowable Archery Range
924
9
Posted in OutsideBackyard
Introduction: Easily Mowable Archery Range
today I will be teaching you how to build an archery range that you can easily now around.
Step 1: Materials
-PVC pipe ( I used 3/4 inch)
-T joint for the size pipe you use
-coupling for the pipe size you chose
-some sort of measuring device( I measured a piece of string at 10 yards to use)
- PVC pipe cutters
Step 2: Cutting Your Pipe
cut your PVC pipe 1 ft long at an angle on one end. this will be you stake.
now cut a piece of pipe at the height you want your yard markers to be.
Step 3: Add Fittings
add a coupling to each stake.
add a T joint to each yard marker.
glue and primer if you want.
Step 4: Drive Stake Into Ground
Step 5: Put Marker On
Step 6: Finished
to mow pull out the markers from the stakes and then mow over the stakes. after that put the markers back into the stake part.
Step 7: Paint (optional)
Step 8: Please Vote for Me in the Hand Tools Only and Hunter Gatherer Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Comments
