I literally stumbled on this while working with hot glue over 20 years ago at a previous job. It ended up being a "major discovery" for how we conducted our "re-work" on defective parts.
After a bit of research on the net I was surprised that even today I can't find anyone else that is aware of this solution. I found that most people are using much more harsh chemicals. That prompted me to create this quick Instructable and share the knowledge.
Long story short - use Isopropyl Alcohol
By John Mangan (siliconghost)
http://www.manganlabs.com
Please RATE my Instructable! If you like this, check out my other Instructables by clicking my username (siliconghost) above.
Background music by 8bitpeoples
http://www.8bitpeoples.com/
Album: Claps and Leads
Song: Funktify
And may you never become unable to hold onto a single blade of grass to keep from falling off the earth.
I have put the rubbing alcohol on the inside of the cover spine area to remove the old hot glue, and I have used it on the ends of the pages that were submerged in the hot glue. I try to keep the alcohol from soaking very far into the pages, but it dries quickly and does note make the pages wrinkle, and I have been quite successful in quickly removing the old hot glue from the books.
Thanks so much for this video. It really has made my repair jobs much faster!
- John
what is isopropyl?is it just normal alcohol 70 %?
Isopropyl alcohol is also known as "rubbing alcohol". I believe it is more like 88% alcohol.
http://en.wikipedia.org/wiki/Isopropyl_alcohol
On a somewhat related note, you may want to check in to these as well:
http://www.metacafe.com/static/perstitial/0/
I made these for mowing my lawn and they work quite well. Allows me to hear the music without having the volume up extremely loud. Not sure if they would be strong enough for jack hammering though. For the cheap price, it's almost worth a try.
You can buy the Earmuffs from Amazon.com here: http://astore.amazon.com/johspro-20/detail/B001BL04PS
One problem i have with your demo is that you're using a lot of metal, metal takes the energy out of the glue faster than it can adhere usually, at least thats how it seems when I do it. If you did a test without metal, that would be nice.
The biggest thing I want to know is does the alcohol dissolve the glue or just help it come off?
The alcohol doesn't appear to dissolve the glue, but it does appear to remove it's bonding properties and it drys the hot glue out (making it very brittle).
It's funny you posted this question when you did because I was just talking with a friend about posting the chemical equation that clearly explains WHY this works.
My chemistry is rusty so that may take some time.
Either way I'm just going to soak that board in some alcohol for a few days to see what happens.
After a bit of research on the net I was surprised that even today I can't find anyone else that is aware of this solution. I found that most people are using much more harsh chemicals. That prompted me to create this quick Instructable to share the knowledge.
