The adapter says 3.7V, 300mA. With that sort of current, you shouldn't leave the batteries connected very long at a time. The voltage on the batteries will go up quickly, but the actual amount of charge will not. Because of this, you have to disconnect the batteries frequently to let them "cool down" (though they usually don't even get warm, the voltage will quickly drop down to around 1.5 V after disconnecting). After they have leveled off (usually around 1.5V) put it back on the adapter for another minute or so. Repeat this a bunch of times to get the charge up. I've just started experimenting, but I was able to get enough charge in two completely dead batteries to start up my power-hungry Canon digital camera and take a few pictures (with screen and flash) and turn it off without it dying on me (died the next time I turned it on). With a better circuit, you could automate the on/off cycles to charge them up.
Remove these ads by
Signing UpStep 1: Get your power source!
You also don't want really high amperage. Since high current charging leads to leaking batteries, try to find as low current plug as possible (look at the mA rating). A good charger has only 65 mA or so going through the battery, but mine has 300 so that's why I have to keep cycling the power to the battery.
Visit Our Store »
Go Pro Today »
So you said "put it back on the adapter for another minute or so". Which means you have to charge the batteries for one minute and turn off every minute??
how many minutes sessions should I do to charge the battery to proper extent?
Correct me if I am wrong, but a friend in Florida told me switching acid batteries to alkaline gives you 1.5 volts per cell, 15 volt output. My car voltage regulator could withstand 15.5 volts. I never tried it. He said the railroad uses this method to keep batteries self cleaning, greatly extending the life of the battery. The alkaline apparently cleans the sulphate off the plates until the alkaline oxidizes them and won't hold a charge. Then covert back to acid he said. Never tried it though.
Secondly- your adapter should have a symbol like + ------ o) ----- -, meaning it is plus-tip (positive centre) , or - ------ o) ----- +, meaning it is the other way around (negative centre, positive ring). Excuse my terrible ASCII art :)
A decent wall-wart adapter will often have a switch letting you change the polarity of the plug, but I would expect all sensible power sources to at least have this diagram.
