Introduction: Easter Basket
Easter festivities are about to begin and It is time to start planning for the upcoming Easter holiday! Start your festive preparations by making these cute little Easter Baskets!!!These would also be perfect for Easter gifts! You could also tailor the colors and use it to give Christmas or Valentine's Day gifts.
These baskets are just the right size for your little one to use at the Easter egg hunt.Also, crochet one of these baskets, fill it with flowers and make it a great display item for your Easter themed decorations.
I like making handmade gifts and I think these Easter Baskets are so much better than store bought baskets because handmade gifts do really show that they were made with love!!!
Materials Used:-
- Yarn
- Crochet Hook
- Yarn Needle
Visit http://rajiscrafthobby.blogspot.in/2018/02/crochet-Easter-basket.html
Step 1:
Start with a Magic Circle.
Step 2:
Chain 3 and 15 Double Crochet in the Magic Circle.(Total 16.Chain 3 counted as 1 stitch).
Step 3:
Slip stitch to join and pull the loose end of the yarn tail to close the gap in the middle.
Step 4:
Change Color.
Puff Stitch in each of the 16 double Crochets.
- To make a Puff Stitch, first pull up the yarn on the hook to a height of a double crochet.
- Yarn Over, insert hook in the same stitch and pull up a loop.Do not complete the stitch(3 loops on the hook)
- Again, Yarn Over, insert hook in the same stitch and pull up a loop.(5 Loops on the hook).
- Lastly, Yarn Over, insert hook in the same stitch and pull up a loop.(7 loops on the hook).
- To finish the Puff stitch, Yarn Over and Pull through all 7 loops.Chain 1.
Step 5:
Slip Stitch to join.
Step 6:
Change Color.Puff Stitch in the chain 1 space from the previous round.Chain 2.
Repeat(Puff Stitch, Chain 2) all around.
Step 7:
Step 8:
Change Color.2 Double Crochet in the Chain Space from the previous round.1 Double Crochet on the Puff Stitch.
Repeat (2Dc in chain space, 1 DC on the puff stitch) all around.
Step 9:
Step 10:
Chain 2.Double Crochet only in the Back Loops all around.Slip Stitch to Join.
Step 11:
Chain 2.Double Crochet in each stitch around.Slip Stitch to Join.
Step 12:
Change Color.(Puff Stitch,Chain 1, Skip a Stitch,Puff Stitch) all around.Slip Stitch to Join.
Step 13:
Change Color.Puff Stitch in the Chain 1 space from the previous round.Chain 1Repeat(Puff Stitch,Chain 1) all around.
Step 14:
Chain 2.Double Crochet in each stitch all around.Slip Stitch to join.(Do not Cut Yarn.)
Step 15:
To make the handle, Chain 30 stitches.Or you can adjust the height of the handle by altering these chain stitches.
Step 16:
Slip stitch on the other end.
Be sure to count the stitches and slip stitch right in the center, so that the handles are in proportionate distance.
Step 17:
Slip stitch in the next 2 stitches.
1 Double Crochet on Each of the 30 chain stitches. Slip stitch to join and slip stitch back 2 stitches to starting chain you made. Make sure to close up the gap by slip stitching through the Handle and the Basket end
Step 18:
Weave in the loose ends.
There you go...!!!! Cute little Easter Basket is ready for Collecting Treats!!!!!!
Here is the easy reference to the pattern :-
- Chain 3 and 15 Double Crochet in the Magic Circle.(Total 16.Chain 3 counted as 1 stitch).
- Slip stitch to join and pull the loose end of the yarn tail to close the gap in the middle.
- Change Color.Puff Stitch in each of the 16 double Crochets.Slip Stitch to join.
- Change Color.(Puff Stitch, Chain 2) all around.Slip Stitch to join.
- Change Color.Repeat (2Dc in chain space, 1 DC on the puff stitch) all around.Slip Stitch to join.
- Chain 2.Double Crochet only in the Back Loops all around.Slip Stitch to Join.
- Chain 2.Double Crochet in each stitch around.Slip Stitch to Join.
- Change Color.(Puff Stitch,Chain 1, Skip a Stitch,Puff Stitch) all around.Slip Stitch to Join.
- Change Color.(Puff Stitch,Chain 1) all around.Chain 2.Double Crochet in each stitch all around.Stitch to join.(Do not Cut Yarn.)
- To make the handle, Chain 30 stitches.Slip stitch on the other end.Slip stitch in the next 2 stitches.
- 1 Double Crochet on Each of the 30 chain stitches.Slip stitch to join and slip stitch back 2 stitches to starting chain you made.
- Make sure to close up the gap by slip stitching through the Handle and the Basket end.
- Weave in the loose ends.
