3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easter Egg Anemometer (Wind Speed Meter)
Easy homemade anemometer, this goes together quickly if you have the parts laying around. This is basically a mini wind generator; the spinning motor produces a current that a multimeter reads.
Inspiration for this project comes from http://www.otherpower.com/
Ingredients:
1 cheap $3 analog multimeter
3 or 4 easter eggs*
1 telephone wire with ends clipped off
3 or 4 - 3" screws*
1 DC motor out of CD ROM drive
1 circular wood cutout from hole saw
1 hose clamp or bracket for motor mounting
1 broomstick or pole
Extras: whiteout, solder, super glue, and electrical tape
*"3 or 4" refers to how many cups you prefer on the rotor.
Step 1DC motor
DC motor
Take the DC motor out of an old CD ROM drive, there were three inside the one I had. Keep the little gear wheel part of the motor to glue the wood rotor onto. Clip and strip the ends of the telephone wire, multimeter leads, and motor wires and solder + tape it together. I used an old CB antenna mount for this but a hose clamp would work well too.
29 comments
Dec 14, 2010. 2:01 AMlisagohwankhee says:
how do you connect the meter to the DC motor again? can you tell me, like step by step? cos I didn't really get it.
Jul 21, 2010. 9:25 PMppsailor says:
Hi ! There is some form to apply in this anemometer some circuit to know the wind speed? ppsailor
Oct 20, 2010. 4:34 AMbeehard44 says:
he's asking if there is a circuit to measure the wind speed being detected by that anemometer
Aug 29, 2008. 11:31 AMoldcolonial says:
How was the unit callibrated?
Apr 22, 2010. 7:27 PMhac says:
You could also calibrate by manually turning one of the cups and calculating the speed using the length of one of the screws (since the cup is traveling in a circular path of which the screws are radii).
Apr 26, 2010. 6:57 AMhac says:
 Of course I should note that this only measures the speed of the cup, which might be slower than the actual windspeed.
Apr 3, 2010. 5:18 PMscratchr says:
You were featured on supergluecorp.com.
http://www.supergluecorp.com/blog/2010/03/30/happy-easter-happy-spring/
(I am not affiliated with  supergluecorp.com, just thought I wold let you know.)
Apr 17, 2009. 1:07 PMoutlawmws says:
Nice write-up; I have just completed calibrating the one I built using your write-up as the inspiration. Main differences: I used the motor for the tray (in/out) from the CDrom. It mounted inside a piece of 1/2" PVC after I drilled it a shade larger (5/8”) and used a nylon bolt as a set screw to hold the motor. I oriented it open end down to keep rain out, and cut a PVC coupler in half to make a drip edge to keep rain out. The wires went inside the PCV pipe through a 90 deg elbow, and to about 18” of ¾ PVC. This larger pipe was capped and two machine screws act as studs for connecting the wires. All the PVC was epoxied, (which leaves a nice bead that paints well) The arms were popsicle sticks, and the Easter eggs were notched on one side, and a small hole drilled on the opposing side to “Key” in a nub I left on the popsicle stick. Again Epoxy was used to attach everything, and again this left a nice radiused bead. Te motor had a small plastic beveled gear, and a flange with slots in it (probably for a motor control bit…) and that is what the Popsicle sticks were epoxied to. I painted it all, and used a tiny fishing bobber with one end sanded off to cap the gear and add epoxy to the hub. The horizontal PVC pipe will be U bolted to a piece of wood, and that will be clamped to some ¾” conduit for a mast. This gets mounted on the roof of the house. Phone wire will run down to the cheaper voltage meter, and yes, the 50ma scale works well. Voltage readings are useless as the voltage tops out at about 1.5 volts and you get no voltage under about 30 mph. The scale is constant from 20 to 50 MPH, at 5 and 10 MPH the marks read differently probably due to low rotation efficiency fall off. What I found was that for 20, 30, 40, and 50 MPH the meters 0-50 scale matched, (YMMV). 5 and 10 MPH do not match any standard step. Thank for the inspiration! -Outlaw
Jan 3, 2009. 11:56 PMncblu says:
you can also use an old hard drive motor, keep the hub on the shaft and any screws that were with it. take an old cd and fasten it to the hub - you might have to tailor it to fit flat on the hub, screw the cd to the hub and mount the eggs to the cd. as for the meter circuit thats entirely your choice. i built one and its working rather nicely
Sep 20, 2008. 3:03 PMamk503 says:
Very clever method. I took an alternate approach, using a small DC motor as the base (and for no other purpose), and essentially turning the shaft into a rotating switch which completes a circuit once per revolution. With the help of a microcontroller (which times each revolution among other things) and some basic math it was not necessary to calibrate the device. The wind speed is displayed with an LCD display stolen out of an old microwave.
Jul 27, 2007. 6:21 PMcodesuidae says:
You could probably use some resistors (and maybe a potentiometer for fine tuning) to adjust the output of the motor to match the existing scale on the meter. Then you could use a digital meter instead of analog.
Dec 7, 2007. 5:05 PMmaker12 says:
how bout a window comp circuit!
Sep 17, 2007. 10:49 PMstatic says:
Here's how the oldtimers tell me how they did this when they where kiddies. Some became friendly with those at a local airport or radio station mounted the homebrew anemometer there and calibrated it to the professional anemometer read out. Others used a vehicle using a jig like otherpower did. They took measurements as they drone in on direction, as well as taking measurements on the return trip to get an average. The more particular also drove a route 90 degrees to the first to have more data to average. As shown at otherpower they made new faces for the meters to measure in MPH. They done this long before PM motors where not as prevalent as they are today. Most used car heater motors that required a power source to the field windings. robbtorfest; did you have the sending unit that low to the ground for testing and photo purposes and, now have it mounted higher to collect the data. for blade design?
Jan 15, 2007. 7:43 PMewilhelm says:
Why are you measuring the wind speed? Hopefully something fun. Around here, we'd rig it up to a big siren that told everyone to drop everything and go to the beach.
Jan 16, 2007. 7:31 AMwombat7 says:
can not wait to see the wind generator
Jan 19, 2007. 7:16 AMShubaltz says:
I made one of thee for a 6th grade weather project (Needless to say, it got an A). I used a brushless DC motor, same as someone mentioned, from an old harddrive. I would reccomend one of thoes instead, as they are alot slimmer, and the main thing, they have less moving resistance. But hey, if it works for you, al the more power to ya.
Jan 16, 2007. 6:14 PMshadymilkman says:
i saw another Anemometer that used easter eggs, but they used an old hard drive motor and used frequency instead of voltage for measurements. They say the problem with using voltage and old DC motors is that at higher speeds, the motor will produce less electricity per MPH. If this miltimeter could measure frequency as well, you could get a more accurate reading buy just swapping motors.
Jan 18, 2007. 10:12 PMshadymilkman says:
i found the site http://www.otherpower.com/anemometer.html its really interesting, and it has several reasons to use an HD motor over regular DC motor. I do admit that at the time i read it i wondered how to make one out of a normal DC motor. There is more than one way to skin a cat i guess.
Jan 16, 2007. 2:33 AMKiteman says:
Sweet.
Regarding calibration, though, you'd have to make sure that the anemometer is well away from the car as you drive, since the displaced air rushing past the car is moving faster than the car itself, plus do it on a *very* calm day, as any wind that is already blowing will affect your results.
Jan 15, 2007. 8:48 PMacaz93 says:
hay , can you add a bit more of information about the measurement of speed ( i mean Explainig How Much mA equals How Many Speed ) And This is one of the better homemade projects i ever seen
Jan 15, 2007. 6:37 PMtheRIAA says:
nice
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
192
Author:robbtoberfest
Stay-home Dad. I like solar energy, boating and sailing, making stuff, melting stuff, and raising chickens.
