Materials:
Computer with printer. Adjust the size of the crease pattern to as large as can fit on a regular sheet of paper.
Paper with the crease pattern printed on it. I recommend card stock or canson paper. Just make sure the paper doesn't split when you fold it.
Straight edge. I'm using a protractor for its straight edge.
Glue or stapler
Either a pen or something you can trace with (I don't recommend a utility knife, although a dull butter knife might work)
Scissors
Side note: The file for the image is not the original viacad file which is cleaner. If you would like the file in viacad or adobe illustrator you can send me note with your email and I will send it. Otherwise just print the pic as large as you can on
By the way sticking an led in it and letting it glow it becomes a pretty nifty light.
TO GO GREEN...This design works well with political handouts that can fill your mailbox at this time of year. Also you can use any thicker material that is already printed on rather than throw it out and put them over led light strings for a custom and green decoration.
Notes I should've added in the beginning: Yes I did create this on my own inspired by a traditional origami model. If you like doing this sortof thing I have a bunch of other crease patterns at http://cedison.wordpress.com/2009/04/09/computer-aided-origami-candy-boxes/ but they are nondirectional creasepatterns and no instructions like here.
easter box.doc29 KB
Remove these ads by
Signing UpStep 1Materials shot
10
comments
Add Comment
sunshiine
says:
Add Comment
