3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy AM Transmitter!
You are going to build an AM radio transmitter AND you will be shown how it works. When you finish your radio, it will look something like mine in the picture above.
I have attached the PDF file in the last step to this Inst'able for those without a pro membership.
Step 1Parts and Prep (Small Stuff)
==These are the small components you will need==
--Small Stuff--
- 555 timer chip
- NPN transistor
- two #103 capacitors (0.01 microfarads or 10,000 picofarads)
- #102 capacitor (0.001 microfarads or 1,000 picofarads)
- some short wires
- two 1 Kilohm resistors
- 10 Kilohm resistor
- 1/8 inch (3.5 millimeter) female audio jack (yours may have more or less than three
    wires, but it must have at least two)
- 5 Kilohm potentiometer
==see next step for bigger components==
263 comments
1-40 of 263next »
May 15, 2012. 6:09 PMjmay13 says:
Where do you get the 1/8 inch (3.5 millimeter) female audio jack.
May 13, 2012. 7:10 AMalex555155 says:
Could I use an 8 Ohm audio transformer?
Apr 24, 2012. 6:55 PMkr.baker says:
A few problems....
The audio is "modulating" the RESET pin on the 7555. This means that the signal is turning the carrier completely on or off, as opposed to linear amplitude modulation. Consequently, the audio will be distorted.
Secondly, Q1 is non-functional according to the schematic - it is acting only as a diode. There is no path from the emitter to ground, either AC or DC, thus there will be no current gain in the transistor and no real power to the antenna. There probably should be a resistor in series with the base, and an emitter resistor to ground. Even better, the antenna should present perhaps a 50 ohm load to ground. That will give much more range to this circuit.
Apr 27, 2012. 8:34 PMkr.baker says:
No need for defense at all... I am NOT an expert in radio. I have 30+ years design experience in analog, digital and embedded systems design, and a little bit of that experience is in HF stuff. No "radio" at all, at least not work-related.
I just approached your schematic from a "general electronics" standpoint, with the issues that I pointed out. From a modulation standpoint, it wouldn't matter if the carrier was RF or not, it still wouldn't be analog amplitude modulation - the carrier is being turned completely on or off, instead of being smoothly modulated by the audio.
The antenna issue is the same, just general electronics, the schematic shows no path to ground.
AM is not too difficult to design - you just need to figure out a method to control carrier amplitude based on the audio signal. There are MANY ways to do that. Analog multipliers, FET gain-control, etc.... FM is a different matter, but still not too difficult to transmit. AM reception is not too difficult, on a primitive level, even SSB is not TOO bad. FM is a fair bit more difficult on any level.
I wasn't trying to put you down at all, just trying to provide some constructive "criticism", if that is even the right word. I didn't want a bunch of folks expecting to build this and think that it would allow them to transmit AM with the quality of a radio station. I was also hoping that my comments might give you (and others) some incentive to explore further and continue to LEARN. Reading and building circuits is the key to furthering your knowledge. Don't rely solely on college or schooling, buy LOTS of books and study. Experiment. Don't just figure out WHAT works, figure out WHY some stuff works and why some doesn't. I've had exactly ONE course in Electronics, about three weeks in high school, and the Physics teacher taught vacuum tube theory. I filled out all my tests with solid-state equivalents.... ;-) So, he made me work, but I made him work too, because he had to research and see if my solid-state circuits really were equivalent!!!! That was FUN!
I'm not that familiar with "Instructables", but there is likely a way to send a message. Let me know if you need some ideas.
Apr 27, 2012. 8:48 PMkr.baker says:
BTW, I can recommend allaboutcircuits.com for a hobby-friendly forum. I'm on there, but VERY rarely. A work colleague of mine is on there a LOT (he's a super-moderator) and there are lots of good folks there that are very knowledgeable. They WON'T do your homework for you though.... ;-)
Apr 25, 2012. 10:03 AMbuppythebupo says:
I am very new to electronics, and I am trying to decipher the schematic. Does the +5v and the ground go to the battery? Great post by the way! Having fun so far!
Apr 4, 2012. 7:50 AMlukas_tek says:
i try one fm spy bug from talkingeletronics.com is very good
your is good too
Apr 4, 2012. 7:49 AMlukas_tek says:
rtty21 the ne555 works?
if not sorry because the many questions i make for you!
if the mensage is wrong try undurstand that
i'm brazilian
i'm noooooooooooooooooooooooooob
Mar 7, 2012. 6:12 AMlukas_tek says:
i use i piece of solder like a antenna it works?
rtty21 my doesnt work i try with 5 volts,7.5 volts and 9 volts.
a try every frequency
a little amp in the audio in
nothing works!
Mar 26, 2012. 10:22 AMlukas_tek says:
yes!
i will try make this again
Aug 2, 2011. 6:23 AMmattman2 says:
if i were to up the voltage going into the transmitter would that increase the range and quality or if i increased the audio input would it?
Aug 29, 2011. 11:45 AMmattman2 says:
OK thanks and would you know how to modify this so it transmits in short wave
Mar 5, 2012. 8:35 PMDKdekes says:
couldnt you change one of the capacitors going into the ic?
Aug 15, 2011. 10:54 PMMROHM says:
Just a Suggestion,,,I would run the Voltage@< 12 v.d.c. (For safety Sake)
Mar 5, 2012. 8:37 PMDKdekes says:
would adding another transistor help the range issue?
Mar 3, 2012. 1:09 PMsalexandridis says:
It's me again! Can I replace the potentiometer with a normal 4.7KΩ trimmer ? Also can I supply the circuit with 9V or 3V?
Jan 31, 2012. 11:49 AMsalexandridis says:
First of all I would like to congratulate you for your well-designed and simple circuit.
I am considering trying to use your circuit compined with the pre-amplifier circuit below:
http://www.instructables.com/id/Pre-amp-to-electret-mic/
Lukas_tek suggest connecting the "output to next stage" to pin 4. What is your opinion on that? If the solution above is not the most appropriate, how can I get a better result using a electret microphone?
Thank you in advance,
Sotos.
Jan 8, 2011. 3:24 PMXDule 97 says:
does the potentiometer control the frequency of the transmiter? can i plug in a microphone? What kinds of transistors can i use, which one will work the best? would a larger antena give about 5 meters? and which frequency is best to tune youre AM reciver for the best qality and range? Sorry for bad english. please answer these questions.
Feb 2, 2012. 1:22 AMmmclsikic says:
Neces uspeti da preguras odredjeni domet zbog ogranicenosti snage ulaznim naponom i snagom tranzistora. Na ulazu u predajnik moras postaviti predpojacalo za mikrofon ili izvesti signal sa nekog uredjaja bez predpojacala ali mu moras podesiti ulaznu impedansu novim potenciometrom. Na izlazu mozes postaviti jos jedan trazistor (izlazni signal na bazu novog tranzistora) koji ce imati zasebno napajanje veceg napona i struje a tranzistor da bude vece snage npr 2N3055.Tada da bi jos poboljsao transmisiju moras izracunati duzinu antene u zavisnosti od talasne duzine koju emitujes i ona mora biti bar 1/4 duzine talasne duzine signala...
Jan 11, 2011. 5:52 AMbeehard44 says:
for the microphone, you cannot directly plug it in, you need an amplifier
Search the web, there are a lot
Jan 21, 2012. 10:21 PMSaad Player says:
hey man, this doesn't work...plzzz help me....I do hear weird sounds from my radio receiver and it means my circuit is working...I connected the audio+ and audio- to my female audio jack, and that female jack is connected to my MP3 player with the help of male audio cable...I've tried the circuit several times by tuning the radio while playing songs in the player bt that doesn't seem to work...I've also used a 4band radio receiver which is extremely strong receiver bt that doesnt seem 2 work 2! any help? :(
Jan 21, 2012. 10:59 PMSaad Player says:
and some more thingzz....I've used all the correct components with the correct values except for the potentiometer which is 4.7 kilo-ohm. and plzz can u give some suggestions quickly?...it is for my science fair project in school this year and I have to submit it by the 28th of this month.
P.S- U haven't given any specifications abt the transistor...any NPN transistor will work? I have used A1015 NPN transistor
Apr 21, 2011. 6:29 PMjwotherspoon says:
would any capacitors and resistors work
1-40 of 263next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:rtty21(My Electronics Project Website)
I'm a 17 year old Electronics enthusiast. I have completed two semesters of school at Minnesota State University in Mankato. I'm pursuing a degree in Electrical Engineering. I like Arduinos, C-program...
more »
