Step 3Output connectors
Another popular type of connector is the banana plug/jack. I don't have any of these, either.
One could alse use RCA jacks. If one had any.
I used the universal connector: solder.
I took some half ounce copper pcb material and cut to size with a jigsaw so it fits over the side of the chassis, next to the hole where the wires come out.
I drilled four screw holes, so that it affixes firmly to the chassis.
Then I took out a tape measure and marked off a spot for each wire
Mark off your lines with a marker
Remove copper with a carbide tipped hand-etching tool
Test "pcb" with a continuity tester
Solder wires.
Cover the connections with epoxy, leaving some exposed pad for soldering connections to. This serves to keep the wires from falling off when you solder other large wires to the solder pads.
I added a thinner copper board over top of this pcb as a "scratch pad." I can remove and replace this "scratch pad" by loosening the screws and cutting any soldered jumpers. This provided a good place for my initial testing, and I'll use it for fabbing up ideas I have for additional control circuitry. Eventually, I may end up making a cover panel with some standard output jacks.
Add Comment
