Play dough is a fun, clay - like substance that kids love! It is very easy to make, and provides hours of fun! It can be expensive to buy at stores, but it's very easy and costs nothing to make it at home! The only materials you will need are:
1/2 cup salt
1/2 cup water
1 cup flour
food dye (any color, be creative!)
newspaper to cover the surface you're working on
It only takes about 10 minutes to make
Some credit goes to my younger sister for the help. (most of the pictures are of her.)
Step 1: Set Up
Find a good work space (I used the floor) and cover it with newspaper. also, find a medium sized bowl for mixing.
Step 2: Add the Ingredients
Measure out 1 cup of four, and pour it into the bowl.
then, measure out 1/2 cup of salt, and add that to the bowl, too.
lastly, fill the measuring cup with 1/2 cup of water and pour it into the mixing bowl.
Step 3: Mix it!
take a spoon - any spoon will do; and use it to mix up the ingredients. Mix it until it's mushy and it's neither watery nor flour - y.
Step 4: Color it!
Add a few drops of food dye to the mush. then pick it up and start kneading it. this is easy, just play around with it. if desired, add more food dye to improve color.
Step 5: Viola!
You're finished! if it's a little sticky, knead a tiny bit of flour into it. use your imagination! you can make whatever you'd like!
It also isnt called play dough, it is called salt dough clay.
