3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Atmel Xmega Sine Wave / Waveform Generator
This is how you can use one of the BostonAndroid.com Xmega evaluation boards ($20)  to create a simple adjustable sine waveform generator with 12bit resolution and capable of producing frequencies from 125Hz - 20KHz using the integrated DAC. You can modify the code to produce any arbitrary waveform at up to 1MHz on 2 channels. You need only a PC, an eval board and a suitable Atmel programmer (AVRISP is under $30 new).
There are a LOT of features packed into the Xmega microcontrollers. This instructable is meant to demonstrate some of the really powerful ones like a 12bit DAC, 12bit ADC, DMA controller and open source compiler (avr-gcc).
Step 1What you need
What you need
You will need the following to complete this project:
Boston Android Xmega EVAL-01 Development Board ($20) or build your own
Murata PV36W103C01B00 Trimpot 10Kohm, 25turn (or equiv from Mouser)
PC with AVR Studio 4 (free)
AVRISP mkII programmer ($30)
12 comments
Sep 29, 2011. 1:19 PMkosmo!! says:
Where i can set the nummer of cycles?
Sep 29, 2011. 2:55 AMkosmo!! says:
I've forgotten:
Is it possible to realize the two fixed frequenz without potimeter?
Sep 29, 2011. 2:52 AMkosmo!! says:
would it be possible to modify this so that it could generate two frequencies (20khz and 22khz) ?
For example:
int data[] = {0, 0, 1, 1, 0, 0, 0, 1, 1, 1, 0, 1};
for (int i = 0; i< sizeof(data); i++){
if(data[i]==1) "frequency should be 22khz" ;
else " it should be 20 khz;
It is possible to add this to the source code and is it possible to adjust the repetitions (loops)?
Sep 23, 2011. 1:27 AMgustep12 says:
Very cool, I like that this instructable is very simple and well-explained. I think I might use this as my first XMega build.
Nov 15, 2009. 4:05 AMprakash.mpv says:
Congrats friend great work....
Oct 31, 2009. 5:37 PMdustin4321 says:
 Can anybody get the ADC working in 12bit? I think this would be amazing when interfaced by a synth ribbon controller or an ondes martinot type deal. Very cool and minimal synth toy. But it would surely need the increase in resolution.
great instructable!
Oct 30, 2009. 8:50 AMmarc.cryan says:
Congrats on the frist X-mega instructable!
Oct 28, 2009. 11:45 PMBerserk87 says:
 Holy crap a true sine wave!
Oct 29, 2009. 5:59 PMBerserk87 says:
would it be possible to modify this so that it could take 12VDC and output 120VAC @ 60Hz.?
basically turn it into an efficient inverter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:wandererwolf(Boston Android)
I grew up in upstate NY where I speant many hours with my brothers playing with legos (I once attempted to test relativity by connecting a large number of gears to a small lego motor.. results inconcl...
more »
