Easy Blacksmiths Forge
Introduction: Easy Blacksmiths Forge
This a forge I made from things I had around the yard
Step 1:
It is supported on a few 5 gal buckets
Step 2: Body/hull
I made the body from a turkey pan, a big pan basically
Step 3:
I cut a. Hole in the center of the pan for the air supply/bellows. I put a pipe flange and pipe in through the bottom of the pan. I use a hair dryer to supply more air to the fire
Step 4:
I filled in the pan about half full with clay and left a bowl shape around the pipe
Step 5:
I Cut a slot in the side for longer pieces of metal , add a grate on top of the hole to stop your fuel from falling in
Step 6:
Smooth the clay and let it dry then light your first fire in the center to cure it completely
Step 7:
I use hardwood lump charcoal to fuel my forge
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    this is more my speed than some of the other ideas for a forge
    Will the spot for the air intake blow the ashes and cinders around?
    Only if there is no fuel(wood, charcoal, coal, etc.) on it and you're obviously not going to be burning ash
    Don't use plastic buckets it got to hot and they melted
