Easy Blow Gun With Paper Darts
 by barri_kid
Step 3: Rolling the paper
First, Take a sheet of paper
Roll it and try and form a cone
Make sure theres a tip at the end, and also make sure that when the last bit of paper is being rolled it is not parallel with the edge. If you do this you will know what I mean (if you dont understand that wording) because it is hard to get it taped when it is like this.
Tape the end
Or
Lick the end and make the paper stick to itself
Cut of the excess "tail" at the end
Also if you have holepunched paper, and there are holes, make sure that the tip does NOT have any holes and no holes are showing. This is for Aerodynamics
vampirewolf says: May 15, 2009. 7:08 PM
I like to use sewing pins. It penitraits 3/4in. in too woood
gangang says: Aug 29, 2009. 9:00 PM
yummylicius!!!
neoisprettycool says: Feb 6, 2011. 3:19 PM
WAY TO FRECIN HARD
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
