3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Boom Pole for Under $30.00!!!
As an amateur videographer/filmmaker, money is always an issue, especially when the discount stores sell products for thousands of dollars. Enter guerrilla filmmaking. (dramatic music).
Guerrilla filmmaking uses super low or no budget methods to make quality (oftentimes low quality) films. This is the method that spawned such indie classics as El Mariachi (Robert Rodriguez) and Pi (Darren Aronofsky). One tool essential to making one of these quality films is the microphone and its portable support, the Boom Pole.
Everyone can imagine in their head the poor guys that have to walk around a film set, their arms above their heads for hours at end holding a ridiculously long pole with some kind of furry animal at the end. This is the Boom Operator, the furry animal is the dead-cat containing the microphone, and that stick is the boom. A really good boom pole can cost upwards of $1,000. Now granted, this is a 36 footer carbon fiber job but even the lower end poles can be expensive. A midget sized 4.5 footer aluminum pole costs about $70.00 and decent starter pole can punch a $185.00 hole in your wallet... Yes, there are some deals out there, but who cares when you could make your own 12 to 16 footer for under $30.00?!
Project Overview:
Build a functional boompole for under $30.00.
Materials:
Painter's Pole
Roller Holder
3/8" screw
additional screws (optional)
Step 1Materials
Materials
The first step in creating your brand new super cool custom boom pole is a trip to the local hardware store.
You need to purchase:
(1) Painter's pole - Look for something around or over 10 feet. 12 - 16 feet is good. Remember though, don't get some huge indestructible pole because some poor sap will have to hold it. Make sure it's light enough to hold but heavy enough not to bend. Expect to pay around $15.00 - $20.00. Maybe a little more, maybe a little less...
(1) Extension piece - This is kind of hard to describe. I used a roller extension and cut off the arms for the rollers however there are several other types. You can usually find these right next to the poles. They simply screw onto the end of the extension and are used to actually mount the brushes. Expect to pay about $5.00 - $10.00.
(1) 3/8" screw - This is used to hold your microphone on the pole. This is the industry standard for all tripods, mic-stands, boom poles. Expect to pay about $0.05.
35 comments
Jul 21, 2009. 10:35 AMNicesites says:
Ok, I got the mic you reccomended from Ebay (* Actually got it for $90!)
I'm still very new to this what exactly are the switches inside the battery compartment supposed to do? They really don't explain it. It says in the manual:
The PAD switch provides a 10dB or 20dB reduction in sensitivity which will reduce the amplitude of the output signal to your recording device
I read it as "Makes it less sensitive to background noises"
Is that right?
Dec 28, 2010. 7:17 PMAlternateLives says:
I worked as an audio tech for a few years, so I might be able to help.
The pad is kind of like a "gain down" on the mic. it simply drops signal output for however much you want.
remember, though, that dB is not linear, but logarithmic. in other words, dropping from -10 to -20 db is not 10 lower than 10, but 10 times lower than 10. therefore, don't use it unless you really need it, such as a really noisy location.
I am sure the mic has many more spicy settings that probably make no sense, such as the hi-pass and low-pass filters. I can't remember which is which, but if my memory serves me correctly, hi-pass lowers high frequency sound, and low-pass does vice-versa. I could be wrong, so correct me if so.
just remember that there is no mic that is perfect for every situation you come across. however, a good shotgun is a great all-around mic to have.
Hope this helps!
Dec 28, 2010. 7:07 PMAlternateLives says:
This is one of the indispensable pieces of equipment used in filmmaking. I am quite glad you posted this. here is some advice for improvement:
first, to avoid the cord slapping the pole, perhaps tether the cord to the pole. this can be done with gaff tape. you could even make wire clips for the pole.
second, perhaps putting a piece of foam rubber between the mic mount and the top of the pole will prevent a good amount of shock from the handling of the pole.
hope these points help!
Aug 19, 2010. 10:02 AMnomuse says:
This worked great...okay, I did modify a little. I got one of those "change the lightbulb" poles. Ground down the threads on the end, jammed a universal clamp-type mic clip on it and filled the joint with epoxy. Used it to capture voice-overs several times, and actually used it as an on-stage practical (for "Bye Bye Birdie" with a wireless mic in the clip. It's become a permanent part of my traveling kit.
Feb 11, 2010. 8:11 AMTheAquired says:
 Hey just a bit information I thought I ought to share...
I have found on the RODE website, an adapter called the VXLR. It is a XLR to Mini-jack converter... Really cheap and is definitely good quality. Here is the link:
www.rodemic.com/accessory.php?product=VXLR
So yea... Hope that helps someone who thought they couldn't get professional equipment because their cameras are not good enough!
Aug 12, 2009. 4:20 PMcwaugh says:
When do we get to see "My kickass Canon Optura 60 modded with my custom Modest 35 (upcoming Instructable)."? Do you still plan on making that Instructable or know of any good ones that are similar?
Jul 8, 2009. 11:42 AMNicesites says:
Hermes, you seem like a nice guy. Here is what I need. I have roughly $150 to spend on a nice boom pole, and mic. I plan to shoot a lot outside, and it's windy here. I like your idea, but trust me, I'm not a builder. I am a computer nerd and I do not play well with building things. So what would you recommend? I'm only going to be about ten to fifteen feet away at any given time. But my camera picks wind up something awful. So to recap. I have $150, I need a good boom pole, and mic. I've actually looked at this mic:
http://www.bhphotovideo.com/c/product/3646-REG/Azden_ECZ_990_ECZ_990_Super_Cardioid_Shotgun.html
Can this bee hooked up to a boom pole? I don't even know how they hook up. Is there anything I should be looking for? Thanks for your help, you are a champ!
Jun 3, 2009. 6:47 AMboobot says:
Hermes, a bit off topic.. I have the Rodemic and want to build this boom pole but my main concern is the audio degradation via the cable. I am currently using my Sony HDR for recording both audio and video. Would a 25ft 3.5mm audio cable extension from the HDR to the Rodemic work for this or would there be too much audio interference due to the length?
Dec 12, 2006. 11:02 PMCrash2108 says:
Yes, but what would you use to record? Simply your camera? What is you just want the sound? Surely you mustn't carry around a laptop.
Dec 14, 2006. 12:22 PMCrash2108 says:
So you just use your camera? Any suggestions on cheap recorders?
Jan 26, 2009. 11:16 PMbrassmnkys says:
Hah...my recordermy recorder set me back about $4k. Good instructable, but you definitely have to have some kind of shock mount, as mentioned previously.
Jan 27, 2009. 12:21 AMCrash2108 says:
Now I think the best recorder would be a small laptop and a USB interface like this.
Jan 24, 2009. 2:44 PMtotallylikecosmic says:
I really like this idea, but my only concern is the lack of shock mount. Wouldn't the microphone pick up every tiny noise and squeak on the pole?
Sep 7, 2008. 2:04 AMlordofthedonuts says:
Have you ever tried the Audio Technica ATR55 shotgun microphone? If so what do you think about it? Sorry for the double post, btw.
Sep 7, 2008. 2:00 AMlordofthedonuts says:
It's a bit out of subject but, what type of 35mm lenses do you use, is it SLR lenses or something else ?
Jan 3, 2008. 1:45 PMahead says:
Thanks for the instructable. This one may go into my media toolbox.
Sep 9, 2007. 6:02 PMtexabyte says:
my canon zr850 doesn't have any audio input what do i do?
Sep 13, 2007. 6:05 PMtexabyte says:
thanks maby i can mod it 4 a mini jack later
May 9, 2007. 3:17 PMDIY Dave says:
What type of microphone should you use uni-directional, bi-directional, or omni-directional
May 12, 2007. 3:43 PMDIY Dave says:
For a mic I prefer a mic that is $50 or less. I would be using the mic for movies. No my camera does not have a XLR port only a 1/8" port. Right now I only have a camera and a $10 philips brand mic(from walmart).
May 9, 2007. 7:20 PMDIY Dave says:
Thanks for the fast response.
Dec 13, 2006. 6:47 AMgezortenplotz says:
I did this boom project right after I created my mic blimp last spring:
http://www.instructables.com/id/EJ2SLSAIB5EP287DUP/
I used a paint roller as a grip, so the boom screwed right into the handle. It worked great.
May 1, 2007. 6:30 PMDIY Dave says:
(removed by author or community request)
May 2, 2007. 6:15 AMgezortenplotz says:
All this project does is keep the wind 'rumble' out of your sound recording. The sensitivitiy of your mic and how close you can get your mic to your sound source is what's critical to how much sound is picked up. Preamplifiers and subsequent sound processing may be needed. Your mileage may vary.
Dec 13, 2006. 8:54 AMstone3408 says:
Great idea. I use a similar device for taking photos at crime scenes. Just mount the camera on the end of the pole, set the timer, and hoist it up over the scene. It produces wonderful overall shots.
Dec 12, 2006. 6:29 PMJakeTobak says:
You may be able to get a similar pole at a pool & spa store.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:Hermes(Portfolio)
I am a filmmaker, student, and tinkerer. I love designig and building devices instead of purchasing them. Instructables is a great way to do that and share with others how to do the same...
