Introduction: Easy Bracelet Tutorial – How to Make a Wire Wrapped Bracelet With Crackle Glass Bead Decorated
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
This is a beginner’s project, it will show you how to make a very chic wire wrapped bracelet, if you want make some easy bracelets, take a look at this one!
Step 1: Supplies Needed to Make This Glass Beaded Wire Wrapped Bracelet:
8mm Red Crackle Glass Beads
1.5mm Golden Aluminum Wire
Golden Cross Chain
Golden Headpins
Golden Spring Clasp
Round Nose Pliers
Long Nose Pliers
Side Cutting Pliers
Step 2: Make the Main Wire Wrapped Patterns
1st, cut about 20cm aluminum wire, slide a red crackle glass bead to one end of the wire, wrap the wire around the bead like the following picture shows;
2nd, make 5 glass beaded wire patterns in total and connect them together like the picture shows.
Step 3: Finish the Simple Glass Beaded Wire Wrapped Bracelet
1st, cut 2 pieces of golden twist chains, the lengths should be about 5cm and 10cm;
2nd, attach the shorter chain to the loop of the wire pattern and attach a spring clasp to the other chain end;
3rd, attach the longer chain to the hoop of the wire pattern and add a red crackle glass bead to the other chain end.
Step 4: Here Is the Final Look of the Finished Wire Wrapped Bracelet:
The colors are very bright and the bracelet is very easy to make. If you want to make a chic accessory for the coming spring days, try this wire wrapped bracelet!
Inspired by craft idea: http://lc.pandahall.com/craft-ideas/13057.html
