**disclaimer!** If you are using incandescent light bulbs, please allow yourself PLENTY of space between light bulb and paper pinwheels! We use compact fluorescents, which give off little heat.
Step 1: Assemble your supplies
I also used card stock-weight paper, construction paper would work well.
brads from a craft store
scissors (don't tell Ryan Gosling I used my fabric scissors, lol! http://handmaderyangosling.tumblr.com/post/18069256038/submitted-by-meejay03 )
darning needle or other large needle to poke a hole, glue gun
I used a rotary cutter and mat, but if you don't have those things, it's still pretty easy to cut a square!
Also pictured is thread that I didn't end up using.
Step 2: Cut your squares
I estimated how many I needed and came up with 15 and cut them in all different colours.
Step 3: Cut in from each corner
Step 4: Poke out 5 holes
Step 5: Assemble your pinwheels
Take one of your brads and poke it through the first hole, with the 'legs' of the brad facing toward you. (follow the steps with the images, it's a hard one to explain!) Then poke the brad through the next hole, then the third and finally, the fourth corner. After you have caught all four corners on your brad, poke it through the centre hole and flatten out the legs. Charming pinwheel! Repeat these steps and finish your pinwheels.
Step 6: Put your pinwheels on your framework
Please remember my tip about using CFL bulbs! And if you are a dinosaur and insist on using incandescent, please have a fire extinguisher handy at all times. (not joking, not a little bit!)
Flip the switch and enjoy your new light! AND, it's just as lovely during the day with the light off!
jessyratfink says:
Mar 18, 2012. 8:46 AMReply
Not Nice
![How to make an Origami Pinwheel Lid Box (Ver. 3) - TCGames [HD]](http://www.instructables.com/files/deriv/FTE/JZO8/H9G122JE/FTEJZO8H9G122JE.SQUARE.jpg)
![How to make an Origami Pinwheel Lid Box (Ver. 1) - TCGames [HD]](http://www.instructables.com/files/deriv/F3S/8LA0/H9G121Y4/F3S8LA0H9G121Y4.SQUARE.jpg)
![How to make an Origami Pinwheel Lid Box (Ver. 4) - TCGames [HD]](http://www.instructables.com/files/deriv/FBG/I1NK/H9G121Y6/FBGI1NKH9G121Y6.SQUARE.jpg)
![How to make an Origami Pinwheel Lid Box (Ver. 2) - TCGames [HD]](http://www.instructables.com/files/deriv/FRN/8I0G/H9G122EG/FRN8I0GH9G122EG.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
