3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Cab (arcade)
Easy Cab (arcade)
Here are instructions on how to build an upright arcade cabinet. I have built a couple of arcade cabinets and have enjoyed learning how to build them and customize them.
a preview video can be seen here: http://www.youtube.com/watch?v=a-3FZYUdghI
I wrote these instructions to assist those who are not yet comfortable in taking on a project like this singlehandedly. I tried to make it as inexpensive as I could, while making it easy to design and construct one with the minimum required skills. I will not be talking about programming or where to download videogame files from, but I’ll offer references to sites that will.
I believe this is a great first project to pick up because not only do you get something awesome at the end but you get to learn about: electronics, soldering, construction, and designing. Once these skills are picked up, they can be applied to other projects.
I used a jigsaw, router, and drill to build this cabinet so the tool requirement is not out of reach for a beginner.
Before starting this project please read though the whole instructions, because there are many different things that can be done.
Step 1Tools:
Tools:
Tools:
Here is a full list of tools that are needed to construct this arcade. If you don’t know what these are you can go to your local building supply store and ask because they will know.
You will need:
ý Drill
ý Drill bits
o 1 1/8th spade bit – I got mine from Wal-Mart in a set for $10 (it needs to be this size for the buttons)
o A drill bit set for various holes – again Wal-Mart for about $14
o A Philips screw bit – usually comes with the drill
o A countersink bit- (used to make the screws flush with the wood)
ý Router
ý Router bit – I bought it for around $17 (it’s a slot cutting bit and ill post a picture , I used a 1/16 th inch)
ý Knife – (to cut the t-molding)
ý Soldering iron
ý Hot glue gun
ý Wire cutters
ý Hammer
ý Jigsaw- I bought mine for $20 at Wal-Mart (make sure you can cut angles, meaning the faceplate can bend at least 45* degrees)
ý Jigsaw blades- cheap like $3 for a couple (buy fine saw tooth or smooth wood)
Here are a couple of pictures that go along with the tools:
40 comments
Apr 28, 2012. 8:40 PMMistablok says:
I am starting one of these but I am having trouble using hyperspin, I can't get Roms to open when you choose a game in the home menu.
May 21, 2012. 6:55 AMsuboxygen says:
man. i'm having the same problem. I guess to the forums I go.
May 7, 2012. 2:38 PMMistablok says:
I am using blue t-molding to give it a Tron look!
May 2, 2012. 4:12 AMmllmTECH says:
Nice cab, I was wondering is the line going down the centre of the control panel a sticker ?
Apr 19, 2012. 3:50 PMsuboxygen says:
nearly there man! up and working but need to finish the front. found some really cheap controller boards on ebay from china.. they work great!! and no soldering, all slip on.
Mar 16, 2012. 8:49 PMsuboxygen says:
this is a great instructable. this is as far as i've gotten so far haha. thank you!
Apr 2, 2012. 7:51 PMsuboxygen says:
another update! we're getting there. we decided against the hinges in front and opted for wireless mouse and keyboard in case we need to make changes. we used MDF for the front and top panel. will post finished product soon enough!
as for the trimming. i think i am going to get the flat LED strips of light. i found a bunch for pretty cheap from china on ebay.. i uploaded a pic with the others from google image search.. something like that, i think it would look cool.
cheers! thanks again uitechclub. will update ya soon.
-josh and marc
Jan 14, 2012. 5:01 AMrezerox says:
This is a great instructable. Just curious which program you are using for your layout design. I've been looking around online but couldn't track down something like this. I tried AutoCAD but that seemed like overkill for this project.
May 14, 2011. 6:46 PMjthroop says:
Thanks for the instructable, I am almost done with mine based mostly on your drawings, used 2 4x8 sheets of 3/4" melamine from Menards $29 each. Ordered the controls and Tmolding from groovygamegear, cut the melamine out on a CNC router, I have the cad drawings laid out on 49x97" sheet (size of the melamine) if anybody wants them.
May 15, 2011. 2:32 PMjthroop says:
The CNC is a 5'x10' machine at work, I used the 3/4" because that's what they had in stock, but it worked great. very heavy yes, next time I would add wheels to the bottom, also I made the bottom door swing out and I will have some USB ports in the bottom of the monitor cover acrylic. I should get the buttons/joysticks on Wednesday. I'll be sure to post finished pictures when I am done.
May 3, 2011. 12:08 PMTomcat94 says:
You may want to include what frontend you used for this MAME machine. The frontend looks very nice!
Also, try using Bootskin to change the Windows XP boot screen to something more arcade-like (or make it not even show up at all, although I don't recommend it).
(This may be just a coincidence, but it seems the design is based on the Centipede arcade cabinet...?)
After I built my first arcade machine, I built a bigger, better MAME machine based on the exact specs of the Mrs. Pac Man/ Galaga machine. It plays everything... Except the exact Mrs. Pacman/ Galaga game it was based on. Oh, the irony...
May 4, 2011. 12:36 PMTomcat94 says:
I'm actually in the process of writing a "Build An Arcade Machine" instructable. Maybe there should be a guide of all the arcade machine instructables, or maybe an ebook of some sort...
May 2, 2011. 4:03 PMtheawesomedude92 says:
(removed by author or community request)
May 3, 2011. 12:48 PMtheawesomedude92 says:
the arcade cab buttons (i forgot to go to step 2)
May 3, 2011. 12:03 AMfesuperman says:
What size monitor did you use?
Apr 30, 2011. 3:57 PMtheawesomedude92 says:
could I do this with a video game console and not windows, i want to use my NES.
May 1, 2011. 3:05 AMWhatULive4 says:
See my instructable. http://www.instructables.com/id/The-Genuine-NES-Bartop/
May 2, 2011. 2:19 PMtheawesomedude92 says:
I went to the instructable, and i was like 0_0, i think i'll just be lazy when building
May 2, 2011. 3:17 PMWhatULive4 says:
It wasn't that bad. You could cut a lot of corners, I just chose not too =)
May 2, 2011. 2:15 PMtheawesomedude92 says:
Don't worry, i've taken my old NES apart before, it was easy, but i broke it. and i have an old TV i can use.
May 2, 2011. 11:02 AMdokcal says:
Nicely done! For some reason, it had never occurred to me to make a shallow arcade cabinet with an LCD monitor.
If you really wanted the arcade feel in a limited space, I suppose you could make one only a few inches deep and secure it directly to the wall!
May 1, 2011. 1:27 PMTiller says:
Nice Job!
If I may so bold as to suggest some parts sources, You can buy buttons and joysticks and almost any arcade part (including coin doors) directly from Suzo Happ and Hagstrom makes a pretty great button to USB interface. If you want a coin door, I suggest finding someone who repairs arcade machines in your city and talk to them. I got a coin door for my machine for $25 with working coin mechanisms and switches. Nothing like having to plug the machine to play.
May 1, 2011. 7:53 AMbb040 says:
nice cab for your first try i would have used piano hinges on the front for the key board drawer...i have a UAII cab i built from scatch and a ms pacman cocktail cab..for those who want to see cabs that will blow your sock off go here......http://forum.arcadecontrols.com
Apr 30, 2011. 8:03 PMramo109 says:
What program do you have for all those games?
Apr 30, 2011. 3:15 AMapoorveinstein says:
how do u shutdown windows???
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:uitechclub
