Step 4: Now the rest of the pieces
Look at very top of the cabinet. Measure the length of the white line that was drawn earlier. My length was 11-1/2” inches, so the piece is going to be 11-1/2” inches by 24 inches
There is an example of all the pieces: Make sure you measure every pieces don’t just base it off my drawings.
A few special notes: (Read this before cutting out all the pieces)
• The drop drawer top edge needs to be cut at an angle. To do this, just adjust the angle plate on the jigsaw and cut it just like before. The drop drawer needs to be trimmed a little bit the in 24” inch way so it doesn’t grind and scratch the sides.
• The speaker mount pieces are also at an angle to make a flat face for the marquee to set on. To make the speaker holes you can drill a hole then cut out a circle or you can purchase a saw hole bit and cut out a 2” inch hole.
• The front bottom needs to extend far enough to cover the bottom piece, so the bottom piece end grain does not show.
(this and the control panel are one of the few pieces that extend over the with line.)
• Route the front of the slide drawer and the front of the control panel pieces, and apply t- molding.
• The drawer slide piece needs to be cut to 23” inches instead of 24” to accommodate the drawer slides.
When I cut out these pieces I would cut a long strip that was 24” inches wide across and then slice it up into the right size.
There is an example below of a long strip being cut to several pieces.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
