Step 4: Re-shuffle
At this point your audience probably suspects that shuffling job just a little bit. So tell your audience that you think it would be better if you shuffled one more time, just to make sure that the pesky card is nice and lost in the deck. Seperate the deck into two halves, then cut each half with one hand, and switch them to the opposite side of the line as you lay them down (refer to the picture). This kind of confuses them. Remember to keep talking.
Now repeat step 3, making sure you keep the chosen card ontop of all shuffled stacks, trying to be quick about shuffling, and remaining as descrete as possible about your dirty little shuffling technique. Once your finishing the shuffling process, sometimes I find it good to mock your shuffling and suggest inconspicuously, and slightly cynical that you are lucky shuffling isn't a crucual part in this trick. Make sure its after you shuffle, or that might get them to look closer at how exactly you are shuffling the cards.
One final tip about the shuffling technique:
Try and switch hands with the stack that has the card ontop of it, just so it doesn't look like one side of the shuffle is always landing ontop of the other.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
