Easy Cleaning - Clogged 3D Printer Nozzle
13,764
80
15
Posted
Introduction: Easy Cleaning - Clogged 3D Printer Nozzle
Cleaning a clogged nozzle is very hard at times. This is an easy and cheap method to clean clogged nozzle.
Step 1: Things You Need
1. Acetone (Nail polish remover)
2. Candle or Lighter
3. Needle
4. Aluminium foil
Step 2: Dip the Nozzle in Acetone
The higher the concentration of acetone lesser the time required.
I use nail polish remover because they are cheap and easy to get.
Leave it for 20-30 minutes.
Step 3: Clean the Big End Using Needle
Remove the plastic using a needle.
There will be plastic left over a the tip which cannot be cleaned using needle.
Step 4: Wrap the Nozzle
Wrap the nozzle in Aluminium foil. Leave the top end open so that the fumes can go out.
Step 5: Bring It Near to Flame
Hold the nozzle into the flame for around 5 minutes. Remove foil and check the nozzle
- If there is still plastic heat it again.
- If it is clean then wash the nozzle and remove any leftovers using needle.
Step 6: Thats It..:-)
Hold it near to any light source and check whether it is clean.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
15 Comments
This was my First Instructable. So please do share your ideas and suggestions to improve my future projects. Please feel free to comment ,share and favorite if you liked it.Hope you enjoyed it as much as I did. Thank you.
modern nail polish removers aren't made from aceton. And if you compare the price to aceton is aceton cheaper (3-5€/l)
Correct! And nail polish removers often have oil in them to prevent drying of delicate ladies hands.
Thanks for this instructable. But, i think that it's ok just for ABS, Acetone has no effect on PLA.
You can use chloroform for pla :)
thanx for the tip.
How do you get the nozzle off? I assume I use an adjustable spanner but I don't want to wreck it doing the wrong thing.
Excellent idea wrapping it in foil, before this I just held them over stove but now with foil they'll look cleaner! :P
I use these, Personally:
http://www.amazon.com/Printer-Clogged-Extruder-Makerbot-filament/dp/B016O43KKC/ref=sr_1_22?ie=UTF8&qid=1453416225&sr=8-22&keywords=3d+printer+clean
I found a sewing pin that was about 1/3mm, and fit through the nozzle to help clean it.
Thank you for this.
