Easy Custom Minecraft Dog (No Mods)
Published
Introduction: Easy Custom Minecraft Dog (No Mods)
About: I like to play Minecraft and I want to be a voice actor. I also like making crafts and other stuff, especially making paper Minecraft figures.
In this tutorial I'll will teach you how to make a really cool dog in Minecraft made out of armor stands! It's super simple and easy, and there are no mods or texture packs involved.
ADVANTAGES OF ARMOR STANDS:
Your friends don't have to download any mods to see your creation
More realistic animals and house objects can be created.
Create a decoy version of yourself to throw off your friends!
Let's get started!
Step 1: The Beginning
First, open up this site, Haselkern.
It should look like the image.
Step 2: So Many Options!
Next, as you can see, there are stuff selected in red. Checkbox the options that are checked in the image.
Step 3: Which One!?
BLUE: These are the positioner levers. Turn the Body lever to the left to the same position as the image.
Step 4: Ooh! So Many Choices!
GREEN: Click 'Enable Equipment'.
YELLOW: Using these you can add stuff to your armor stand when you spawn it
BLACK: Select the 'Chestplate' slot and change it to 'leather_chestplate'. Notice that on the right there'll be a color bar. Change it to whatever color the head of the dog will be (I chose grey since it matches the color of the head I'm using)
LIGHT BLUE: Put in the username of the player's head you wanna use (I put in Auntsiss_Is_Boss).
PURPLE: Select 'Item Name' and change it to 'Player Name'.
Step 5: First Order
PINK: Copy the command, then open Minecraft.
Step 6: Will It Work?
Paste the command in a command block (how to obtain command block: /give @p (username) command_block).
Step 7: Where's the Other Half?
This is how the it should end up looking like.
Step 8: Back Here Again...
GREEN: Notice that the armor stand is now turned around. Move the 'Rotation' lever to the middle until it looks like the image above.
RED: Take out the username so that when you spawn this armor stand it doesn't have the head on it.
Copy the Command on the bottom.
Step 9: Good Doggy!
Paste the command in another command block right behind the first one.
It should look like the picture above.
And you're done! This is 100% armor stand made. So if you want it for a server or realm, you're all set!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Thanks! I might make another entry for how to make other stuff out of armor stands.
    Don't forget to leave a vote!
