loading
Step 2: Modify Your Pumpkin (be It Art or Actual) to Fit the Tip of the 5 MM LEDs.
As a ballpark idea, the size of the LED tip that you will need to install inside your source you'd like to light up is slightly smaller than the diameter of a pencil.
So, if a pencil can fit inside, you can easily mount / stick the LED in and mount it (be it with sealant or glue, but let's not get ahead of ourselves!)
I used a handy metal instrument to insert into the source and pry a proper opening that allowed the LED to fit snugly, in the next step we'll group together the 12V Prewired RGB LED wires (simply ground and power) & then install and mount the LEDs.
It's that easy!
Oznium has already done all of the wiring of the RGB controller, resistor & polarity protectioninside the wiring!
Next, let's group the wiring together and mount them inside the art-work / pumpkins!
About This Instructable
7,785views
14favorites
License:
Bio: LED, DIY and Automotive / Motorcycle Lighting Enthusiast. http://www.oznium.com/ http://www.oznium.co.za/
More by Oznium:Easy DIY Color-Changing Halloween LED Decoration Lights - Pumpkin & Accent Lighting LED Undercabinet / Under Desk Lighting with Dimmer and Wireless Remote Installing 12V Color Changing RGB Lighting
Add instructable to:
