Easy DIY Crystal Lamp
5,244
102
Published
Introduction: Easy DIY Crystal Lamp
About: i like to make stuff that can help people or make people laugh and have fun , :) and love sharing it on instructables
i realy wanted a lamp or my new rose quartz tip , so today im going to show you how to make a cheap one , or free!
Step 1: Type
pressure and timed :
you will need
  • LED
  • canister
  • 9V battery
clip :
  • battery clip and all of above
Step 2: LIGHTS!
for pressure :
wrap the wire from the led around the positive and negative poles of the battery. but just loose anough to fall of when there is no pressure.
clip on/of:
solder the led to the battery clip.
Step 3: PRESSURE!
if you chose to make the pressure sencor lamp:
  1. slide the battery up the canister.
  2. make sure the led is off.
  3. push the canister onto the battery to make the connection with the led.
Step 4: DONE!
the size of the canister was perfec for my quartz tip.
hope you like this instructable i thought it was a easy life hack to save your money!
thx
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Looks great! You might want to add a current limiting resistor to let the LED last longer. 470 Ohm resistor would be my choice with a 9 volt battery.
    thanks for the feedback :)
