3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy DIY Electric Motorcycle Conversion
Step 4Cutting The Swing Arm
The swing arm modification is probably the most challenging part of the metal work. It requires a hole to be cut out of it to make room for the motor. Many people have correctly commented that cutting into the swingarm can seriously weaken it, potentially causing problems. This is partially true, but the final design takes that into account - The placement of the AC motor helps to strengthen and reinforce the swingarm stiffness.
This step requires precision - the motor must sit perfectly in-line with the rear wheel, so that the chain travels straight between them without any flex or twisting caused by misalignment. We used both a square and straight-edge to mark the cut lines with precision.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:sparkyrust(Gomi Style)
Marque Cornblatt was born in Baltimore, Maryland and now lives in San Francisco. He holds an MFA in Conceptual Arts from SFSU; has a diploma in theater technology from the Baltimore School of the Arts...
more »
